So I've been searching the forums trying to figure out what the issue is with LB. Up until now, the issue has been as follows:
Insert Key, Turn to On: No CEL, Cranks, but doesn't start.
Replaced Fuseible Links, check EFI relay and Fuse, Checked ECU: All Good
On a hunch, I disconnected the wiring harness at the MAF. Sure enough, when I turned the key to on the CEL turned on and it fired right up! However, as soon as I apply throttle is dies immediately.
So...now what?
So...now what?
glad you got running
