I have been having intermittent problems with shifting and wanted to get some thoughts from guys with experience. My 93 has 183K on it.
Transmission seems to be losing 2nd gear. Will start OK in 1st, then shift to 3rd. If I give it some gas to shift down into 2nd it will rev WAY up, and then slam into gear.
Used to do it when cold, we adjusted the throttle cable, seemed to work for a while, but then it started again. We flushed the fluid once, and then I added some Trans-X, and that seems to have made a difference when cold, but now it does it after the truck heats up, as in highway driving.
Today it drove OK for a while, then started acting up, at one point it revved to 5500 rpms when trying to go up a slight grade at about 35 mph! I let up on it asap, and limped home. I'd hate to see this turn into a head gasket issue with all the rpm spikes putting undue strain on the motor. I added more trans-x today after this episode, but it didn't make much difference when hot.
I've been trying to drive around it, but it feels like it needs a re-build. I hear how rare that is in 93 transmissions, though, and would like some ideas on what it might be.
Thanks in advance.
Thanks in advance.
