93 hdj81 RHD clutch slave and master PN?
Truckee ca
Hi there,
I'm helping out a friend who has a '93 HDJ 81 right hand drive JDM truck and is in need of the part numbers for the clutch master and slave.
I have searched here, there and partsouq (which I always have a hard time navigating from my phone) , haven't really come up with anything definitive.
Figured someone here might know them off the top of their head so....
Thanks in advance
PS: his truck sat for a while while he was out of the country and the clutch Master leaked all of its fluid out, so we replaced that with what we thought was the right part but now his clutch pedal is super sticky and doesn't return to the high position. It does have the sprung clutch pedal assembly.
We bled the heck out of it, 99% sure it doesn't have air, but what is concerning us now is that the new master we installed was not the same looking as the one we took out, and it has a smaller bore apparently.
Just trying to get the proper matching set in there.
Thank you
Having a few cruisers to play with, and sometimes needing parts I have found that if the mounting holes/bolts line up the parts usually work.
Your slave shouldn't have to be specific to make and model.
I have another unit from a new HZJ79, and the only difference is that it has a pivot fitting, which can help with angles. Can't remember if that is on my 1991 hzj75 or the 1995 hdj80
Unfortunately I am in the process of moving, otherwise a picture would be included.
reach out to Georg Easter, orange45, he can make sure you have the right parts, valley hybrids stocks what you need, the little extra is worth it for the tech help and you can get it today if needed
