93-94 Engine Wiring Harness ?
Hayward, Ca.
Ok guys question... My pesky heater hose before changing, leaked all over the connection that connects the wiring to neutral safety switch on transmission. Over time coolant leak actually ate some of the terminals on the connection plug from NSS and what I believe is the Engine wiring harness.. So does the Engine wiring harness (part # 82121-60341) have the connection plug that connects to the Tranny Neutral safety switch?
Negative. The NSS is a part of the transmission sub-harness: 82125-60081 which is discontinued from Toyota.
If you can get the 5 digit connector number off of the damaged connector it might still be available from Toyota separately which you can then splice into the main transmission sub-harness assy.
Best regards.
-onur
Onur, so I take it that the tranny sub harness does directly connected to the engine harness? This would make it a lot easier to get to in order to replace tranny harness rather than replacing engine harness I take it?
