'92 V6 4runner NO ELECTRICAL POWER! Help?
It ran fine, no problems what so ever, took the battery out for another vehicle, when I hooked the battery back up...no power..no dash lights, no anything. Just dead. I changed the terminals, checked all the fuses in the fuse box under the hood and in the fuse box inside by the drivers door, everything looks fine. Im completely stumped. Worked fine one minute and then 20 minutes later, its simply dead...any main fuses that could have blown somehow, and the location of them? I need this thing back on the road asap. Any help is much appreciated...
Thanks
I'd get a miltimeter and start checking how far your power is getting.... Or that there is power in the battery... maybe the bat had a catastrophic failure.... Check your ground connections... and the condition of your battery cables...
Good luck! And welcome to Mud!!! :flipoff2:
Likely the fusible link or main ground.
There are 2 wires that go to the positive side of my battery, the little wire going to the battery broke (fuse box box power wire) broke on the inside but the plastic coating was still in tact and was covering the severed wire so I couldn't see that it had broken on the inside and wasnt even getting power to the fuse box
