Just wanted to say a BIG Hi and Hello to all, this is my first post and it is about a problem I am having, what a way to start on a new Forum ………. So this is my story
I bought a 1992 Toyota Truck 4x4 ex-cab 4cyl 22re motor with 185000km, Ran fine but sometimes had a squeal between first and second I thought it was the throw out bearing so I posted it on an other forum and they said to try to start the truck off in second gear. So I did this a few times and lugged the motor, with no squeal
After I did this the motor started to make a weird noise, its almost like a loud Growl that comes and goes. I took it to a local Toyota guy and he said that it did not sound like the timing chain (what would the chain sound like) he suggested it was in a pulley, also said that it sounded like it was not getting oil to the top end …. I was OMFG …… and I didn’t use the those letters ……… I had to drive it home,
So if the oil was not getting to the top end the motor would have been knocking it brains out by now …….. it was a fair drive back to the house …… How would you check to see if the top end was getting oil ? ( I am thinking start it up with the filler cap off and if any comes spitting out oil is getting to the top end )
My next step is to take off the belts and run the motor for a SHORT time to see if the noise is in one of the pulleys.
How could I check the tension of the timing chain ?
What do you think ?
Thanks
Jon
What do you think ?
Thanks
Jon
