92 speedo/cluster bounce?
AU
howdy howdy
bought a 92 Aus spec gxl 80 series the other week and am haveing probs with the speedo needle bouncing. sometime when you slow down the neeedle gos up to 80km and then gos up more when you stop and then will fall down etc. the tacho and other guages seem to work fine.
Has anyone had this problem ,Can any one help me with what causes this, would it be the speedo in the cluster itself that would need replacing or something else, are they cable or elc in the 92's not up to date with 80s im usually hiding in the 70 series section
Thanks all Clint
You should find a cable that is driven by the rear output of the transfer case (in a fulltime 4WD xfer). The inner cable (the part that spins inside the sheath) can be pulled out, cleaned, lubed, and re-installed without too much effort from under the truck.
You can check the speedo drive gear by removing the rear driveshaft and putting a small flatblade screwdriver in the slot that drives the cable and then turn the rear output flange of the transfer case. Make sure it's smooth.
If the cable checks out and the drive gear checks out then the only thing left is the gears inside the speedometer itself. You can check this as well with a cordless drill on the end of the speedo cable with another set of eyeballs in the driver's seat.
ah excelent info jonheld
thanks very much for the helpfull info
ill have a crack at it over the weekend
cheers clint
I pulled the same came on the transfer case, cleaned it. It worked for about a month, then I eventually replaced the speedometer cable. cost about $120 for the part. took a long time to install because you have to follow the cable all the way to the tach/speedo cluster. goodluck, and have a lot of patience. I should have taken pics, but it was dark and messy.
