92 LC possible Alternator problem
Yacolt, WA
First off Thanks in advance.
Yesterday my wife called after taking our 92 LC through the carwash saying the At/temp light / brake light / charge lights were all on and the truck would not start. Jumping got it started but it did not want to hold a charge.
After searching it looks as though this is common with a bad alternator. I just today replaced my battery with a Autozone Group 27 Gold Series 750CCA for 910Ca and 135 reserve capacity ( for those of you wondering) $75 bones. :crybaby:
My questions are:
1) Could it just be loose belts? I have tightened slightly and the lights now go off when driving.
2) Is there a more common problem my FJ80 may be experiencing? Any suggestions before I buy a new expensive alternator?
3) FYI 91 and 92 have an external fan and to replace the brushes requires soldering. Is this worth attempting:confused:
Any opinions will be appreciated.
Thanks HEFE.
My questions are:
Definitely could be loose belts. That'd be cool if that's all it is, huh? :D
Bad alt. is by far the most likely scenario. But like psfpilot says, get it tested before replacing.
Good question; I actually have no idea. :confused: Don't forget that the regulator is in there as well, so if that's the problem, well...
Good luck,
Curtis
Many discount auto parts stores will test your alternator for free.
Just to branch off of this for a minute..
If you decide to get the alternator tested, remove it first. That may be obvious, but I didn't know that for a long time.
If you decide to remove the alternator, it's easiest when you remove the smog pump beforehand.
Make sure your alternator pulley is on tight. Mine was loose and tightening the belt helps for a while because the pulley gets twisted a bit. The next thing that happened to me, of course, is that the little alternator fan hit the housing and self destructed. I found that the alternator comes out easily all by itself.
I'm a bit confused by this statement. If the motor is not running then the those lights SHOULD be on. The next question is after the truck was started, did the lights stay on? If so, then that points to a fault in the charging system. Usually it would be a bad alternator, but seeing as this just started after a car wash I would say it could be as simple as a poor connection or possibly a loose belt. Also, be sure to check the mounting bolts on the alternator.
Just don't buy a advance or napa alternators... I have been thru 3 of them in one year. Something with the amount of heat coming of the manifold that just melts something inside and they malfunction. This is on my 91 by the way.
I'm glad I'm seeing this thread...my '92 just starting doing this in the last couple of weeks. It doesn't happen all the time, but only every once in a while. The AT Oil Temp light will stay on, the BRAKE light will stay on, and the warning light above the voltmeter gauge will be on. When I blip the throttle a little, they all go off and the truck runs fine for the rest of the day...no alternator whine, no charging issue, no problem holding the charge throughout the day.
So, I'm thinking it may very well be a loose belt or a loose connection on the alternator. I'll have to check those things. My belts are only about 500 miles old...so I know it's not the belts going bad. I did my water pump back in June, so of course I loosened a lot of parts and equipment in the engine bay...the alt. may not have been bolted back down correctly.
Dave.
Dave.
Dave I think the brushes in the alternator are wearing down.
You should be looking for a good replacement.
I second what FZJ80_YV saids about after market alternators.
After I replaced my original on a road trip in 2000 due to worn brushes, I have gone through 4 after market. The first just stopped charging after 14months. The others all were overcharging, 16+ volts and just last night I put the spare on because it was over charging.
I will open the one that is overcharging and see if I can replace the voltage regulator. The FSM has good info on this.
Thanks for that info...I suppose it was about time to replace it anyways at 200k miles...as far as I know, it hasn't been replaced yet...at least, I don't have the records showing that it was (and I have tons of records on this thing since new).
I just went through this with my 92 a few weeks ago. Remove the smog pump related hoses, remove the alternator (FSM useful) and have it tested at an auto parts house, because the dealer requires it be "on the vehicle". If it is dead, order the replacement from cdan. Even my :banana: ability was able to complete in a few hours. Good luck!
It's really fairly easy to do this. I did it just last week, I'm maybe :banana:& 1/2 or :banana::banana:, but it's easy stuff. Just takes a while.
Update
Well Thank you all for your info. Well it ended up being my alternator. All 3 lights are now off as they should be.
Unfortunately my wife uses ours as her DD so I bought a reman one that has a lifetime warranty from Schucks. I believe it is Autlolite! I wanted a new OEM but funds are tight right now and I need to be saving for my Front Axle Rebuild and oil pan R/R.
I still have my old alternator which I plan on dissecting at a later date.
By the way how hard is it tio change the oil pan on a 3FE??? I have searched and most seem to refer to the 1fz:frown:
I will keep you all posted on the longevity which I am hoping is a long long time.
Thanks again for the tip on removing the air pump first.
HEFE
Expect to get a new alternator within a year... Most of those aftermarket parts, if not all, don't last long. There is a reason Toyota parts are so expensive.
Have a looksie in the 3FE Yahoo group, loads of info. Also check over in the 60/62 section... The 62 guys should be able to help, same engine/tranny.
Yep, I would think about having a spare alternator.
My research has found two types of alternators for the 1991 92 fj80, external fan and internal fan. I have only used the EF type, In the top picture.
Has anyone used the alternator in the lower picture? I would like to buy one as a spare. Brushes and voltage regulator on this one are held in by small bolts not globs of solder like the EF type.
...oh I did my oil pan a while back,...I still remember. 15 hour job, with hammers, chisels and a propane torch. no more oil leak:grinpimp:
The bottom one is a 90A alternator. Rare on the 3FE's. I would LOVE to have one, but CDan told me they were incompatible...
cruiserdan said:
The 80 an 90 amp units are not interchangable. The most common one is the 80 amp. That one has an external "fan" right behind the pulley.
I would like to find out why the 90amp won't work?
Is it a fit issue?:confused:
Does Cdan have the answer?
:flipoff2: Looks like I will have to buy one and find out the hard way why it won't work...
Some folks, like me, must learn the hard way unless they're educated by the Parts Shaman...
This thread has been officially hijacked.
