92 HDJ81 radiator-where to get?
It fit very well, only thing was the fan shroud attachment points at the top didn’t line up on the right (drivers side) so I fabbed a piece of aluminum for a bracket and is solid. Yes, Impex charges shipping after/separately.
Awesome thank you! Do you confirm the amount before they ship it or do you just have to pay whatever it ends up at? And no damage from shipping?
The radiator at my dealer $390 and it was at the dealer. What's different?
Yes to confirm for shipping after order is made. No damage that I could see, NO leaks at all, been in since May 2024. It has the transmission “cooler” barbs on the aft facing side on the bottom.
What part # did you get? Does it have the ATF loop in it?
No because that atf loop sucks and a trans cooler is a necessity on a diesel.
I added an after market trans cooler from wholesale automatics similar to what is found on the US gas powered 80’s.
The only issues was one of the tabs did not light up. I ended up getting the correct fan shroud for it. Can easily mount the existing fan shroud with some custom brackets.
