92 Cruiser
Bay Area, CA
I had noticed that my rig is really slow under 2000 rpm but once it reached 2100 rpm it seems like I get an extra Horse power. Please
advise. Thanks.
That's pretty normal for a 3FE powered rig (88-92).
If you really think it's beyond normal and want to pursue it, the following cut and paste (from the 3FE Yahoo Group) is the only valid approach I've come across.
Welcome,
Curtis
P.S. John Hocker is a well respected Toyota parts person.
Hocker sent me the 3 VSV's Vacuum Supply Valves for a FJ80 as the ones for the FJ62 are discontinued. My Air Injection VSV was shot for sure according to the tests in the FSM.
Just that one is available but its $67 whereas the whole mount with all 3 is $105 from the esteemed Senior Hocker.
Here is the difference, the FJ62 VSV's mount horizontally and have perminent wiring on two of them. The FJ80 ones mount vertically and all can be unplugged.
I used the mount rail from the FJ62 and just swapped the new VSV's to it, they unscrew easily.
Another difference is that in the diagrams the #1 and #3 VSV's are in opposite locations on the diagram which I will attempt to attach and will post in a writeup in the files section when I get a minute.
That is to say I needed the forwardmost VSV (closest to the front bumper) which is the Air Injection one. In the diagram it is called #3. However, in the diagram for the FJ80 it is labeled #1 and is the rearmost one. I will try to get the actual part number off of each and post what they do in my writeup.
The old ones from my FJ62 had perminent wiring on number 1 & #3 VSV's, the middle one #2 just unplugged. I tried to dig out the silicone to see if there was a plug underneath but the wires were clamped onto the posts so I diked them off.
I used blue butt wire connectors on the diked off ends and had to trim off the flared end of the butt on the side that goes into the VSV. They fit snug and I believe will stay. After I am sure I will probably fill the area with di-electric grease and seal it off.
Results. If you look back at the symptoms I was seeing, sluggish or flat acceleration through about 23k rmp then turbo kick in like jump on up. Also, my idle was about 950 rpm at idle which is a bit high. I was getting dismal mpg as well. Jon Held said this sounded like what his rig was doing when his EGR system laid down. I had just replaced my EGR and vacuum modulator so I figured it was something else. I had checked my timing and it was retarded. Perhaps because my CEL due to the fried O2 sensor wiring for the front one. After I replaced the engine wiring harness my truck was CEL free but the symptoms began.
I am thinking the ECU reached an equalibrium with the fried harness and the timinmg was set accordingly. Regardless, after I advanced the timing performance improved but the problem still existed, it just moved higher up the power band.
With the new VSV's I Warmed up the truck and test drove it. It idled at about 550rpm smoothly. It pulled consistently through the power band without the flat area I saw before. It still pulled harder above 2700rpm but I think that is just the nature of the beast. It is really noticeable in 3rd gear when I hold it and shift at 4k rmp. For those who do not know I have a H55F Toyota five speed transmission. From 3k to redline the thing really goes.
My hot rod is baaacck!
Dunbar
Oh, and death to bin Laden.
If the motor is in good tune to start with and you're seeing a "turbo boost" at 2200 RPM then you're on the right track. I had replaced my VSV valves to no avail. When I replaced my EGR valve and EGR regulator (2 flying saucers on the left side of the intake manifold) everything got better.
While my EGR valve was totally plugged with carbon poop, I think the underlying issue might have been faulty vacuum. The EGR valve diaphragm had turned to powder and the vacuum ports were rusted and plugged. This caused numerous vacuum leaks/blockages in the system.
After 15 or 16 years, these things should be replaced as PM.
Oh, and don't forget to clear out the hard lines that live by the 3 VSV valves. This would also be a good time to replace all the soft vacuum hose (one at a time).
With proper vacuum restored, not only will the motor run better, but your brakes will work better too.
Thanks Jon
I know I will have to replace the EGR valve & EGR regulator. Would this also fix the "Check Engine" problem? Known problem with 91 & 92?
The EFI relay wiring is a known issue, but that wouldn't throw a CEL... Do you know how to pull the code?
Yes, I used a paper clip and count the blinks on the dash :D. I will pull the code again to make sure when I get home today.
Appreciate it. :beer:
Update
CEL. I have code 25 & 26.
Rig still runs fine. Idle a little rough.
Idles at 500 <--- is this normal?
I will be very busy for the next coming weekends.
So, it could be from wiring harness around the EGR
wiring problem from 02 sensor or sensors?
Cleaning TB, ground bolt might be loose? etc .....
RIG runs fine even I have the CEL on for almost
a year now but i guess I will have to take care of
this issues.
So, it could be from wiring harness around the EGR?
Nope; that's a 93-97 issue only.
How many miles ya got? O2 sensors degrade and wear out; If they're old, replacing them is likely to get you better performance and mileage.
Oh, and idle should be 650. Although, mine's lower than that and a little rough. Meh.
Curtis
this issues.
25/26 indicate a lean/rich condition = O2 sensors....IIRC
I don't have my handy dandy bookmarks....I'm staying at my friend's apartment for the weekend, so I thieved...borrowed...her laptop. :D
Appreciate all the help
I have 220, 364 miles. I have the rig for 10 years now.
Mostly freeways/city driving and once in a while snow
when going up to Tahoe.
No major repairs. Replaced power steering pump,
twice alternator, 3 batteries and not sure if EGR
modulator. I used to have code 71 and even after
replacing the modulator it just keep coming back.
so I just cover the CEL with black electrical tape :D
It does passed smog with no problem but I make
sure that I reset it first so no CEL.
92 has 2 02 sensors? How much and good place
to get it?
to get it?
Go OEM. 80's don't like anything aftermarket. Ask me how I know...
They are a little $$$ though, call/PM CDan for pricing.
to get it?
Dang dude.
Somehow I read your first post as:
"I had noticed that even though I have always kept up on all preventive maintenance, and have always addressed problems as soon as they arose, nevertheless my rig is really slow under 2000 rpm but once it reached 2100 rpm it seems like I get an extra Horse power. Please
advise."
Shame on me. :lol:
