I bought a '92 FJ about a month ago knowing that the cruise control did not work. I've been doing a lot of searching on here, reading everything I can find on diagnosing the problem. I do not have a FSM yet but I am working on getting one. I'm going to Colorado from Arkansas on the 13th of this month and would REALLY like to have my cruise working. I did the diagnostic check found at this post ... https://forum.ih8mud.com/80-series-tech/175440-cruise-control-help.html. Set/coast gives me two flashes so it checks good. RES/ACC gives me three flashes so it's good also. When I pull cancel, hit the brake pedal, pull the emergency brake, or put it in neutral the light goes out so all those sensors appear to be fine. However, I'm having a hard time understanding how to check the speed sensor. This evening, while driving I had it in the diagnostic mode the cruise light was on regardless of any speed I was driving. If I understand what I read in the post I linked to above, the cruise light should blink when the speed sensor makes at above 25mph. Do I understand this correctly? If so, would I be safe in investing $100 in a new speed sensor? I did remove the speed sensor but found no dirt, and not really any way to clean it. I wiped it down and reinstalled it but no change. The cruise control is something I'm used to using and willing to spend money in order to fix it but I don't want to waste money by buying parts I don't need.
Any help would be appreciated! Thanks, Brad
