'92 A440F Trans Cooler Question
Ann Arbor, MI
How should I disconnect the cooler lines from the trans? Damn fittings won't budge...
I had the same trouble on my a442, need more lube on there up on the lines above the nut. you need to get 2 wrenches in there one to hold the fitting and one to turn the nut, otherwise you could break that fitting off, also once you get it moving go back and forth loosening and tightening so the nut doesn't bind and ruin the hard line. Might as well remove that drive shaft and shifter linkage.
Thanks for the reply. Can I remove the fitting from the transmission instead and then separate the tube from the fitting? There is a sensor in the front fitting. I assume this is a temp sender in the inlet line coming from the cooler.
This job can be a pita! I had to do it when I first got mine. The line was rotted. Remove the linkage as suggested above. Mine was so rusted and stuck even after spraying with penetration oil it wouldn't budge with wrenches. I ended up getting it to crack free using a large adj. wrench to hold the part with the sensor and a pipe wrench on the line fitting to crack it free. Once loose I used regular wrenches to work the fitting back and forth on the line also mentioned above. I can't remember but I think I cracked the sensor loose before the line and removed it too to make room?..
I got the shift linkage and drive shaft out of the way, but I still can't get the tube nut to loosen up. I've been soaking it with rust penetrant. I'd rather not use heat on this with all the oil in the area.
Got any ideas on how else to loosen this up?
My only other thought is to remove the sensor, cut the line, and remove the fitting. I'm hoping someone has another idea first...
Penetrating oil for a few days, add some heat from a torch, more penetrating oil.
This sucks. BTDT.
Thanks, Jon. I'll get the fire extinguisher within reach and the MAP gas torch. Its the hottest thing I've got.
Is there anything I need to worry about with trying to remove the temp sender?
I don't recall pulling the sender when I dropped the transmission. It was just the 2 cooler lines that took forever to free up. The compression fitting corrodes to the hard line and it takes time and penetrating oil and heat and time to allow it to turn freely. Things like this are why it took me so long to replace the rear main seal. Folks on mud said it's a 1 day R/R job. It took me 2 days to get the damn transmission out.
