92 3FE slow start
Yacolt, WA
Hey Guy's,
I have a 92 with the 3FE. It seems to crank for a few seconds before starting. I want it to start quickly. She use to fire right up.
I have recently tuned it up all OEM. Including plugs, cap, rotor, pcv valve + grommet, starter contacts, reman Toyota alternator, newer battery. I have also replaced all vacuum lines.
I have cleaned my throttle body (not removed but sprayed really well with throttle body cleaner). All fluids have been replaced as well as fuel filter and sock in tank.
Does anyone have any other suggestions?
I have not checked my timing but my truck seems to run very well. I just got back from a 1,300 mile round trip to Tahoe and it bugs me she cranks for a few seconds before firing.
Any help would be appreciated.
HEFE:beer:
I've noticed the same lately with my '91.
Sometimes, if she sits for awhile, she won't even click the starter.
If I open the hood and let it sit for awhile she starts fine, but still takes several cranks to start.
Maybe it's just the hot weather?
I will need to check the thermo-switch. I thought I had ruled out the EFI (it hasn't died on me since the fix) - back to the drawing board.
I have the same problem, I just removed all the injectors including the cold start injector and had them cleaned/flow tested. It runs smoother and starts somewhat quicker, but it still takes multipull cranks to start. The next thing I am suspecting is a worn distributor, but I don't want to replace that on a hunch. How many miles do you have, mine has 220k. The problem got really noticeable after 190k
mileage
I am coming up on 160K. And I do not want to replace my distributor either.
I have not done my injectors yet. My truck idles pretty smooth. I averaged 15 mpg with the wife 2 kids and all the necessities my wife seems to think we need for a week in Tahoe.:rolleyes:
Yeah mine got to the point where it would not start for 10-15 seconds at a time, sometimes for an hour. The injectors did cure that.
Same problem on one of mine,runs fine,7-10 cranks to start. Pump pedal it starts. I dont think its injectors or dist. wondering if its another d....am relay. MIke
Just thought Id do a search. Mine takes about 2-3 seconds to crank over. It has right at 200,000 miles. Always starts strong and runs great. Just never heard another LC start and was wondering if they all crank for a few seconds before turning over.
I have the same problem on occation. I remove and clean the cold start injector. That thing gets very dirty very quickly. It always helps the start up. . . until it gets dirty again. Also, make sure your throttle body cooling fan is working properly. If this fan does not cool the TB quickly when you shut off the engine, then it will not start right away the next time you try to start it.
I changed the fuel pressure regulator on my '91 and it has fixed some of the issues with the start but not all. Any pics on the cold start injector?
Definitely take a look at the cold start injector. A poorly performning or disconnected cold start injector will dramatically impact cranking time. On my 3FE I found that one of the terminals was backing out inside of the housing (so I'd push the terminal housing onto the cold start injector and this would push the terminal back instead of making contact with the terminal on the injectory). This caused cold start cranking issues because the cold start injector wasn't firing.
Unfortunately I believe that the cold start injector isn't pulsed (it is either on or off) so you can't listen to it tick to see if it is actually firing. I believe the test is to pull it off and hold it over a bucket while you crank the engine. In may case however I could simply see that the terminal was pushed out of the housing.
