92 3FE FJ80 Run issues
NSB-Florida
My 92 will start, run with absolutely no problems for a week, 2 weeks, then all of a sudden not start. Turns over, can smell fuel, once in awhile will start and stall immediately. After a week or so, start and run fine then do it all over again. When it runs, I can drive it around for 30 minutes or so with no issues. Replaced coil, igniter, wires, plugs all vacuum lines, refi relay, fuel pump, ECU, TPS, just about everything except for the distributor. After I replaced the TSP, it ran great for a couple days then back to its old self, same with ECU. Ran great for a couple days, no start issue then all of a sudden, no start.
Any clues as to what it could be?
Have you replaced the fusible links by the battery, it's a common problem with these 80s,another common problem is the wire leading to the EFI relay from the factory is under sized causing the relay to heat up do a search for EFI relay wiring, also when it is in the no start condition check to see if the CE light is on with the ignition key on, if no light when the ignition is turned to the on position then the ECU is not getting power, these are all very common issues on a 92 intermittent start problem use the search bar or pick up a FSM.
When it is in the no start condition is the CEL light on with the key in the on position?
And
Have you checked for spark during these no start conditions?
CE light on when attempting to start, checked for spark on the back side of the coil. Since it has like 230K miles, I just replaced the coil and ignitor with Denso components. Have not checked for spark at the plug, limited with assistance to turn the key while verifying. One man band here.
I would replace your fusible links by the battery they're very cheap and probably should be replaced anyway, like summit says it would be nice to know if you had spark at the plug that would eliminate a lot, try to get your dog to turn the ignition key while you check for spark
New
Screaming AFM/fuel pump logic to me.
New pump and regulator replaced within 30 days as well as TPS. Has me baffled. As mentioned, I can out there some days and it fires right up with no issues, drive it for a couple days then out of no where will not start. Weather has nothing to do with it for it will fail whether it is cool, damp, hot and dry. Makes no difference. Check engine light not on. Only comes on when turning it over. On the days that it does start, check engine light goes off after start and it runs like a million bucks. It needs someone more mechanically inclined than myself to trouble shoot obviously. If any of you are in Central Florida and are willing to check it out, come have at it. I will gladly pay the diagnostic fee.
New
Like I said, AFM and fuel pump logic. I didn't say fuel pump, as that obviously works.
The fuel pump is fired by 2 different circuits.
When starting, the first coil of the circuit opening relay is triggered and that fires the fuel pump when the starter is cranking.
The second coil of the circuit opening relay is triggered by the flap in the AFM when the motor starts to suck air. When you release the key from the START position when the motor catches, the fuel pump continues to run.
If the AFM is damaged OR the flap inside the AFM is restricted in any way by debris, OR if the circuit opening relay is faulty OR any of the logic is faulty, the engine will fire and stall as soon as the key is released from the START position.
