91 wont start???
Murfreesboro Tenn.
This is for my brother who has a 91 FJ80. A while ago his wife was driving it around and it seemed to run out of gas. So we get it home and then get some gas in it to see if it will start and it wont. Here are the issues that we are thinking could be the problem. Just want to run it buy you guys to see if we are on the right track.
1. We know that the injector seals are leaking pretty bad. Could this cause the fuel to not have to pressure to get it running?
2. Could it be the fuel pump? How often to they go out on 80 series? And is this something we should look into.
Or is there something that we are not even looking at and could be the problem. Thanks in advance.
Micah
bump.
Most of the time if a 3FE won't start it is the EFI relay.
Not sure if that is the problem from what you have said but if you know the seals are bad, replace them.
It could be the fuel pump, they do occasionally fail, do a pressure test and find out. :D
Does the CHECK ENGINE light come on when you turn the key to the ON position?
Not sure about the light due to the fact that the light was always on when it was driving. o2 sensor.
could also be the sock filter on the fuel pump. When they get clogged it acts like you are running out of gas.
I didnt think about, great idea.
