'91 HZJ80 A/C System questions/problems
Lahore - Pakistan
Hello everyone, I'm new here and just bought a HZJ80 series
I'm having some problems with the AC system - the AC was low on refrigerant(R12), so I went to my nearby ac tech and started to find the leak. The front EVAP needed replacement and so we did, after everything checked out pulled vacuum at 29inHg for like 3 hours.
The vehicle is equipped with a refrigerator and rear AC as well, everything is working OK now except that the whenever 'COOL' or 'ICE' button is pressed on the refrigerator the compressors starts cycling on/off - same thing happens when 'REAR COOL' is turned on.
if only front AC is turned on it works fine, but if either the fridge or rear ac is turned on - the compressor starts cycling on/off - this didn't happen before...
questions:
1 - if front/rear AC is off, should the compressor turn on if 'ICE' or 'COOL' button on the fridge is pressed?
2 - what can cause the AC compressor to cycle on/off when the either fridge or rear AC is turned on??
help would be much appreciated
regards
First, remove both the ice-box and the rear unit and send them to me. I will install them in my 80 to see if they work correctly. If they do, you won't have to worry about getting them back. In all seriousness, when the system was charged, were the ice-box and rear unit turned on? Perhaps not enough refrigerant was put in?
thank you for the reply
I can always send you the photocopied units :p
yes all units were turned on, maybe the system is low on gas
but the problem I mentioned didn't happen before when the system was seriously low on gas :/
Quick cycling is usually due to overpressure in the system. In a nutshell, the pressure switch sees high pressure and cuts the compressor which decreases the pressures in the system. As a result the switch turns the compressor back on, and the cycle repeats.
Does the compressor short cycle immediately after turning on the fridge or rear AC? If so, I'm stumped. If it takes a little while then your condenser is getting heat soaked, and you'll need to figure out why.
here is an update - sorry for the delay
while tracing the root cause of the problem under discussion, the rear AC stopped working all together - the rear block valve turned out to be bad. I tried a little tapping here and there but it wouldn't loosen up so there the refrigerant went out we replaced the block valve with a new part, leak checked and then vacuum the system for about 4 hours.
Have put in about 1300grms of R-12, front ac is a chiller including the fridge, as soon as the rear ac is turned on front ac cooling performance is hit - does this mean low refrigerant? pressures are fine..
also note that the system cools better at about 1100 RPM not at idle ~800..
OK - been a long time but here is an update:
the rear unit had a BROKEN expansion valve nozzle inside, that is why everything was being messed up, other things were nice and fine, its been working NICELY since that fix.
