'91 Cruise Control Problem.
Houston
Website
www.andrewsshizzle.com
My cruise control doesn't work. The light comes comes on, just does not grab. Can yall tell me where to look for the problem?
I'm hoping to get some quick responses, I just lined up with a buddy to cruise junk yards tomorrow, so if I need to look for a part, that would be the time to do it... I'll post up another thread about that.
Thanks
Andrew
Have you tried it while on the highway after a few miles of steady driving? Mine initially does not grab most of the time. Bit after being persistent with it, it can grab and run fine (when it grabs).
No, I've tried it on and off, not persistently... I'll give it a shot..
Check to see if your throttle cable is adjusted right. Then check the actuator on the passsengers side fender. Mike
I now where the actuator is, what am I checking for?
Andrew
There is a method for testing it, I don't remember off the top of my head. Very likely it is the speed sensor. It comes off the back of the transfer and gets caked in grime.
Is this where the speedometer cable connects to the transfer case?:confused:
Thanks, that is what I needed. From the second thread, is this the FSM troubleshooting proceedure?
<snip>
A. Turn the ignition switch on.
B. Turn the control switch to SET/Coast position, and keep it there.
C.Push the main switch ON.
D.check that the indicator light "CRUISE" lights-up in the
combination meter.
E.Turn the SET/Coast switch off
F.Meet the conditions listed in the table below.
G. Read the diagnostic code on the cruise control indicator light.
#1 Turn the control switch to SET/Coast position
there should be two flashes and then a second break and then two
flashes, then break then two flashes etc. If you get the flashes your
SET/Coast circuit is normal.
#2 Turn the control switch to RES/ACC possition.
this time you get a pause and three flashes, repeated again and
again. if you get the three flashes RES/ACC circuit is ok.
#3 Each switch is turned on
a. Control switch to CANCEL.
b. Stop light switch, (step on brake)
c. parking brake switch. ( pull up parking brake)
d.Neutral start switch. ( put in neutral)
if when you test each of the 4 cancel switches you DO NOT get any
flashes then those switchs are normal.
THIS IS YOU, And now you have to leave the driveway.
#4 Two parts for speed sensor
A. Drive at 25mph or below. if there are NO flashes sensor is normal.
b. Drive at 25mph or over. you should get constant steady blinking.
if she blinks sensor is ok.
</snip>
ok, I misread the speed sensor test, it failed the second test.
Not sure what I'm looking for, it looks clean. Has a clunking sound in it when you shake it. when I turn it with a screwdriver it turns smooth, but it is noisy. Noisier than I think is should be...
Andrew
Andrew
I think along with the onboard test you performed (and that it failed), there's also a bench test outlined in the FSM.
It's very likely bad though.
Oh, and you said it looked clean. No gear oil seeping into it through the speedo housing?
yeah, real clean. incidentally I found out that FZJ speed sensors are different. I finally found a 92 in a yard today, and guess what? It's a Saudi import, 92 fzj80 with the 1zfe..
This is the second one I've found, I know another guy around town with one.
I did manage to score the factory tool kit and jack stuff from it for $5.
I also found 2 of the GM retractable trouble light assemblies for $10 a piece, one for the FJ one for the Jeep.. Was the coolest thing gm ever did..
PS I know where at least 3 more of those light assemblies are if anyone around Htown is interrested..
a
Andrew
