91-92 vs 93-97
Just buy a '94, dude...However, all 80s are great! I smile even when I see a stock one coming towards me on the road. They are relatively rare...You also will end up getting your :princess: a highlander or 100 series and keeping the 80 to build...:D
Ive bought a 91 and a 94 new off the dealer lot. I must say that Ive enjoyed the 94 much more. May not seem like a lot of HP difference on paper but my 94 had at least a little get up and go compared to my 91.
Since this will be your wifes car you should consider a 1995/1997 80 with standard airbags if safety is a priority.
Go out and drive both engines and make up your own mind.
Ill bet you go with a 93to 97 FZJ80 :p
Best of luck with your search
Pete
What timing belt would you be refering to? 1FZs have very sturdy low maint. timing chain.
Yep, meant to say chain...you got me there.
Just how "low maintenance" is not having one to change at all? :D
The "F" motors have gears, early ones solid, later composite that are known to have issues. It's not common, but nether is 1FZ chain failures. Overall the 1FZ requires less maintenance, the scheduled maintenance valve adjustments are a pain on the fuel injected F motors.
Thanks Everyone for your comments and information. It is difficult to get the live feeling of the owner relationship by just hard facts. Your owner comments are helpful.
3FE has nothing to do with Firetruck, IIRC the F is the engine family, E indicates fuel injection.
The 3FE and 1FZ curves.
attachment.php
This sure makes it look like the FE has both a high % of maxer and higher raw pounds of torque at IDLE when compared to the FZ? Is that correct? Was it incorrect in the comment above that said the FZ had 2/3 or 3/4 of its torque available from idle? It would seem, from the diagram, that the FE is the better "off-road" engine with more usable low end torque
also, it also appears the FZ never reaches its designed maximum of 275 pounds of torque?
Berzerkeley,
That is the horsepower and torque curve for the 3FE. The smaller attached image is the horsepower and torque curve for the 1FZ. (horsepower curves start lower and move up linearly, torque curves are more flat).
If you look closely at both images, you'll see the torque advantage advantage that the 1FZ has. Both have fantastic curves though.
I don't see how the idle torque makes any difference, both motors have enough torque to turn the pumps/accessories at idle? Both motors are delivered in the US attached to an auto trans, so from a "driving" stand point idle doesn't matter. The torque converter stalls in the 1800-2000rpm range, below that no/little drive is delivered. I don't see where the 3FE has more torque, the 1FZ makes more at 1000rpm than the 3FZ at max.
My point previously, with the 2/3 to 3/4 at idle, was to demonstrate the available low end torque that the 1FZ has. And yes, Bezerk, it's true.
Kevin, are you saying that the 1FZ's torque with an auto tranny is useless below 1800-2000 RPM?
attachment.php
Yes, sorry, mild (and failed) attempt at levity.
The "F" series engines do have their genesis in post-war inline-6 engines Toyota first produced for their domestic market. The lore (and it may be apocryphal) was that they were first used in public service trucks, such as first-responders as ambulances and *ahem* fire trucks.
Looks like I'm coming in late in the game...but...
#1, asking $$$ is WAY WAY TOO F-ING high! As many of you have read in my words, if the asking $$$ is too high, you're not walking away with that truck for $3,250. And simply by talking to them you reinforce an asking $$$ that is too high IMO. My sorta high mileage '97 LX 450 which has a SUPER clean body, was bought for $6,000 with factory locking diffs. So to me, that further makes a 3FE powered truck with an asking $$$ of $4,400 seem really high.
YouTube - used cars - high prices
Note...the real f-word is in the clip so if you don't like bad words...don't click on it! You've been warned!!!
#2 I don't care what anyone says, the 3FE is better than a 2F and an F motor, but c'mon man, it is an anachronistic power plant. From smoothness, to power deliver, to general under the hood niceness, the 1FZ is a WAY WAY better engine. I'm sure many will disagree. The fit and finish, under the bonnet, of the 3FE juxtaposed to a 1FZ powered rig is laughable. It seems the 80 was built around the 1FZ and the 3FE was "fitted" to the FJ80.
If it were me doing it again, I would for sure go with a '95 or newer FZJ80, with airbags, adjustable front seatbelts, leather, factory lockers, etc. If I could find a FJ80 with a push rod motor for $1,800 that was really really clean...maybe I'd buy it and keep it as a winter beater but otherwise, no way. 21st century man....get yourself some DOHC goin on under the hood!
And did I see someone used a synonym for spurious in an earlier post? Is this vernacular far too erudite for a forum where dudes discuss cars and whatnot?
The rig will move under that speed, but from a using most/all of the available torque viewpoint, yep it's pretty much useless below torque converter stall. I haven't seen a dyno chart for the torque converter, but by watching the tach you can get an idea of where it happens. Watch the tach and accelerate briskly from a stop, on my rig the motor speed/tach will move quickly to ~1800 range then more evenly match/speed up with the rig speed from there up.
In the rules of thumb of motor design there are three main points: First torque converter stall, should be where torque is ramping up/close to plateau. Second is full load shift point, should take advantage of max horsepower. These two are referred to as the drivability range, on my rig it appears to be about 1800-2000 to 4800-5000rpm. Third is most efficient cruise, usually close to where torque and horsepower curves cross. From my observation it looks like Toyota nailed all of them, knew what they were doing.:hillbilly:
Thanks - very useful information! Makes me wonder what other things we could be doing with a manual tranny and that, still, somewhat useful torque between idle and 1800 RPM. As much as I love my 80 with the auto, there are still some things I miss from having a manual at crawling speeds. I just hate being on the brakes so much. The 80's auto drive train is well built and very forgiving, but with the 1FZs low end torque, I'd love to try a manual for a while. Prolly just get lazy and come back to the auto, though:D.
Thanks, again!
a bit different to the 80's i know but for motors i had i fj 75 with the 3f which i sold to a mate, now have a fzj 79 with the 1fz-fe and when we go 4wding off road the 79 it just has so much more noticeable torque and power, unstoppable and holds gears so much more in boggy sand even gets better on the fuel economy and tis a bigger motor.
Yep, big efficiency difference between 2 valve, push rod, '40's tech and 4 valve, cross flow, pentroof, overhead cam, '90s tech design. That combined with the fully counterweight, 7 main bearing crank make it rev much better and run smoother.
Thanks, again!
Why would you want a manual? The only possible place where I would see it as an advantage would be if your using it as a tow rig and '80s aren't very good at that anyway.
The best analog that I have is the FJC. IMHO with the same upgrade setup (lift, bumpers, 35's) they come the closest to keeping up with the '80 of any of the later model Toyotas. There are a ton of them in our club, I have some seat time and a ton of spotting time with them. In the tight stuff the manual rigs have a big handicap, they are too heavy and geared too high. You could add a crawler box, but then would have the manual/crawler issues and they are much worse in a heavy rig.
The auto works well, will crawl all day in hot weather. IMHO the torque converter slip is a great thing in a heavy rig, greatly extends drive train life and is forgiving to drive. The only way I would have a manual/crawler setup would be in a light weight buggy, but even then I would probably put an auto in it and that's coming from an old school manual only guy.
Hi,
My question is, for those of you who have owned BOTH FJ80 powerplants (4.0 and 4.5) Would you pass up a good deal on a 91 in favor of continuing your search for a 93-97?
Just mainly an ownership satisfaction rating of the two models and if it is worth waiting for (and paying more for) a newer model in your opinion after your ownership experience with both.
This is to be momma's car mainly on road use. I might add that I have never driven a 4.5, and I find the 4.0 to be sluggish on acceleration but satisfactory at highway speeds.
Thanks!
I owned both a 92 and a 97 for about a year and drove both of them on a daily basis. Both trucks had stock size tires and gears, both had Slee Sliders, and the 97 had a TJM Bull Bar.
The best summary I have is that the 97 felt like it was a 1000 lbs lighter than the 92! (Even thought I am sure it weighed the same or more).
The 97 did everything faster - accerating, cruising, stopping and turning and it got 13 MPG in city driving where the 92 got 9-10 MPG in the exact same circuit. Not only does the 97 have more power, the brakes are much better. Also the suspension tuning changed somewhere between 92 and 97, the 97 suspension was much tighter in corners.
I personally would never consider buying another 91-92 unless I was planning on replacing entire drivetrain (i.e. diesel swap and portal axles). The 93-97 have full floater rears with disks, better front brakes, get better MPG, and have more power. Paying an extra $2000 for and FZJ would be well worth it.
The :princess: certainly liked driving the 97 much better too. (Although now she has move up to an 05 UZJ).
As side note, I know a lot of people are not airbag fans, but that is a plus for me of the late FZJs.
:cheers:
Jule
Two things a manual can do that an auto can't:
1. Bump start the engine (if battery/solenoid probs)
2. Use starter to move vehicle short distance(with safety circuit bypassed)
Yeah, I know, nit picky and prolly not used all that often the way most folks wheel in groups, but a nice option to have if you wheel alone.
I'm with you there, but I still like the direct drive of the manual for engine braking at lower RPMs.
It just would have been nice to have had a choice, instead of marketing decisions or government/EPA pressure dictate what was sold here.
I wonder how an e-locker for the torque converter
would work. Have it auto unlock at say, 500 or maybe even 300 RPM. Might even get better gas mileage and have some on pavement advantages.
You're not wrong...
I've read somewhere that '95 was the transition year from from partial OBD-II to full OBD-II , sometime in '95.
I could be (and probably am) wrong though...
As for me I would choose a '96(full OBD-II for sure, maybe) or a '97, just so I can run Scangauge.
My $0.02.
That's correct...the Jan '95 got the 442 tranny and OBD I, while the Feb '95 (mine) and forward got the 343 tranny, and the OBD II fully compliant.
Though I have not owned a 91-92, I know people who do, and they mirror some of the remarks said here. I believe the 91-92 rigs are a great vehicle, however, presently the FZJ can be had for the same $ or little more. As long as you have the privelige of choosing...you would do well to consider anything manufactured after Feb 1995. Just my $.02
Thanks everyone I offered him $3800 for the 91 we will see what he says.
The Truck is in beautiful shape. Paint looks like its 6 years old instead of 18.
