I've done the searches, and it appears the people with $$ & experience opt for the OEM.
My radiator is all metal (copper?), no plastic, aluminum. Is this factory?, or has it already been replaced?
I didn't see any mention of having them repaired/cleaned?
I'll steer clear of the aftermaket ones I think.
I'm not %100 sure it's the radiator, because I can't lay my eyes on it, but I will soon. It/something has been leaking for about 2 years. In the past few months it's required a quart or 2 a week, and now I need to top it off daily (been using water) to the tune of a gallon or better, so it is time to address this problem.
I have a local radiator shop that I've used in the past, most recently on my Jeep, I've also requested them to not repair it if it requires bypassing any of the cores.
Anyone have any thoughts on repair vs. replacement?
btw, other than a bad thermostat a few years ago, I've never ran hot, I know it leaks and check it frequently.
I think it's a leak on the upper 1/3 of the radiator, because it will leak down to a certain level with the car turned off and no pressure on the system. I'm almost certain it's going to be a radiator, I just haven't put eyes on it yet, the leak must be blocked by the shroud.
I also read in a PP that someone used Simple Green to clean out the condenser, this sounds like a great idea, I think I'll mix some up in a spray bottle. Anyone have any reason not to do this?
Thanks
Andrew
Thanks
Andrew
