Uhmmm power goes up as octane goes down. Octane is a measure of how "fast" fuel burns. More refinement = higher octane= less energy per fuel amount. It a common misconception that higher octane gives more power as it is run in higher performance motors, because these motors have a higher compression ratio. However, you may get less power as the computer in the LC retards the timing to avoid knock.
I have no disagreement with that summary, and that's how I understand octane works as well - but your conclusion that "power goes up" reducing octane is not correct. Combustion energy potential goes up, but that doesn't mean 'power' goes up. I claim the power and efficiency of the engine is down because (higher octane = more timing advance possible <>) lower octane = less timing advance possible, and results in a noticeable difference in reduced engine power. I understand and believe that is due to how knock vs octane and fuel tabling works in ECU programming.
cruiserdan said:
Wow.
You are the only guy on the planet with a 93-94 that does not have a knock issue at WOT without some sort of fuel enrichment/octane boost.
How is that possible?
I run the stock boost, stock tire size/weight and darn close to the stock truck weight. Quite possible one of the only SC guys on this forum to do so? I don't think there is any magic, I do it quite often. IME with high performance FI engines, it's quite possible to run lower octane fuels. IME with program tables in knock sensor motors, it's quite easy to see and feel the "regular" fuel tables, or timing retard performance differences.
I've run the tanks of 87 fuels back to back with 93, and the performance difference is noticeable. And BTW, when I was on the way/at Steamboat Spring CO Ice Track 2 weeks ago, 91 Octane was available at all altitudes above 6500ft, including all downtown stations at 6700ft. IIRC, octane fuel availability is a state mandate, not an altitude mandate in the US.
My point to the OP, is that 90 octane will not harm the SC if that's the highest octane available. He would notice a difference in performance running 93 in the midwest, that doesn't mean he needs 'octane' boost using the highest grade fuel he has available.
Scott J
94 FZJ80 Supercharged
