90 2wd tranny question
Scottsdale Arizona
Howdy,
I have a90 2wd that came with a 4 speed can it be changed to a 5 speed with no problem? if so does anybody have either a 4 speed of 5 speed they want to sell?
Thanks
Kyle
:bounce2:
I have an entire rolled 91 truck for sale. Complete with transfer and trans, drivelines, etcetera for 250. If you are willing to wait until the Christmas break I can yank the trans/tcase, or you can come pick up the whole thing. I'm in Utah though. I can be reached at 801-814-1034 Marc.
Ok, Its a 4 speed manuel is there any issue in replacing it with a 5?
Does anyone have either one?
Kyle
Shouldn't be any issue, unless it doesn't fit in where the 4 speed fits?
I'm a little confused though.... I thought they stopped making 4 speeds in the early 80s........
Do you see it here? :
http://www.marlincrawler.com/htm/transmission/transmission.htm
Or can you get the tranny code of the info plate on the door jam?
IIRC, the '89-'90 models were still available with the 4 speed manual if you opted for the carb instead of EFI. They're pretty common the 2WD's of that vintage.
Hmmmmm I guess that makes sense..... sort of.... I saw a 2wd with a carb and a build date of 92 in a junk yard one time. I wonder why they did away with the 4 speeds on the heavier 4wds, but not the 2wds? Seems if overdrive was ok with a carb on a 4wd, why wouldn't you want it on a 2wd? Cost probably.
