Oil is leaking from the rear of the engine it seems to be running down along the outer bellhousing but I can't pin point it since the exhaust crossover is in the way,is this a common leak that other have experienced.
The engine has had work done on it previously looking at the gasket sealant on all the top end parts so I would think it is a case of a proper gasket was not used or was not installed properly , I just need some ideas what to look for without doing a tear down...it is spewing fairly heavily even after 10 minutes of idling.
