88fj62
Status
Not open for further replies.
Toronto,Canada
Parting out an 1988 fj62
I have almost the whole vehicle available. It has the brown interior. Biege exterior. You can PM your parts needed lists to me.
Here is a brief list of some the parts I have for sale.
Fuel Tank complete with pick-up and sending unit-$175
Cooling Sytem Parts:
Radiator-$100
Radiator shroud-$35
waterpump with clutch fan with fan blade- $80
thermostat housing-$40
Engine parts:
mounts- engine- $60 Pair
Smog pump-$75
Air cleaner assembly-$40
a/c compressor $75
Motor Mounts-$50
Cylinder head complete with rocker arms-$350
push rods(complete set available)- $4 each,
head bolts (complete set)-$4 each
valve cover ---$30
Power steering pump complete-$175
fuel injectors complete with fuel rail-$220
Intake manifold-$200
exhaust manifold-$80
engine block with pistons , crank shaft --$250
Transmission parts:
Shifter-transmission console with base plate-$50
Transmission mount-$40
Flywheel--$70
Torque converter-$200
Body Parts:
Seat- frt dr brown-$75ea
Seat Rear brown-$100
Hood-$150
Hood hinges-$30
Hood balancers (springs)-$60
glass for frt doors-$50
glass for rear side doors(large)-$35
glass window cargo area-$45
Door -fuel filler(brown or gray) -$10 ea
Door-fuse panel brown-$5
Door Panels( interior brown) -$35 ea
Motor-windows regulator-$100
Switch-power windows-$30
Glove box(interior box) -$15
Bumper-rear- $125
Electrical parts:
Airflow sensor-$180
Wiring harness(complete) $125
fan-engine cooling-$30
fan-defroster-$35
ECU-Electronic fuel injection control computer module-$100
Hi, I’m interested in the yoke off the steering shaft that connects to gear box. (It’s the telescopic part about a foot long.) If you still have it and are interested in selling would you let me know what you’re asking price is? If you prefer calling over emailing, I’m at 416.875.8507. Thx so much.
I will contact you. Thx
Hello Mike, do you have the chrome trim for the rear license plate light? Mine is rusty. Thanks!
Looking for the front axel housing, and the steering box.
Got em?
Chicago
Status
