Did the relay solve this?
OK think I have made a little headway. It took for ever to figure out the CIRCUIT OPENING RELAY is a FUEL PUMP RELAY. Why is the that not made more obvious in the FSM. I can understand how valuable the FSM is for testing but why doesn't it tell you the location of a item. From the diagram the Circuit opening relay looks like it is in right behind the valve cover on the engine side of the firewall. I read and searched the forums to figure out fuel pump relay and its location. The FSM was great for testing the relay once I found it. It was bad, found a replacement will try it tomorrow. Thanks
