- Joined
- Jan 3, 2011
- Threads
- 3
- Messages
- 20
Ok this is not my first time I've done a belt but I get a lot of pinging and loss of power.
Now here's my issue for some reason in my service book I have for some reason marked on the t belt installation page 10deg tdc. Now I totally don't remember if I wrote that cause I wasn't able to remove the harmonic ballancer? Or was just high on brake clean. Could this be my problem? So would placing the crank at ten deg. And line the cams to the dots fix this? cause I've tried a tooth forward and back on distributer and it gets worse. Even checked twice to see if it skipped a tooth on the belt. I have a brand new long block from Toyota and did a valve job with new valves and even did leak down tests.
It seems to be in the timing. Cause once I replace the ball joints and tie rod ends this truck is better than when it rolled off the show room floor. It doesn't run b
That bad just pings a little bit.
