I'm helping a buddy with his recently acquired '88 Chevy 350 TBI engine (K5 Blazer). The engine had some work done, and then wasn't started for almost a year. We've gotten it running smoothing and starting well, however, it begins to overheat as soon as it warms up. Even with as many F/2F/1FZ engines I've worked on, I'm domestic dumb.
The rad is new, the W/P is supposedly so, and we just changed the tstat.
Apparently this is a wierd year that has some kind of "reverse flow" waterpump that looks and bolts on the same as earlier models, but flows in the opposite direction. It is the year with one ribbed belt and two v-belts, if that means anything.
We are trying to determine if the waterpump on it could be incorrect. As the engine warms up, the lower radiator hose will warm up and that corner of the radiator (crossflow type). None of the rest of the radiator will get hot, even as the engine begins to overheat. This leads me to believe the waterpump is the wrong model and is not effectively moving the coolant like it should.
Just to check my thoughts- coolant should be "pulled" from the radiator at the bottom hose and enter the radiator through the top hose, correct? So wouldn't this mean that the top hose and radiator surface closest to it would be the warmest, right?
Anyone familiar with this oddball or have any suggestions?
