88 3.0 auto to 89 22r standard swop
Jewett Ohio
I was told this was a plug and play swop. I now have the engine in but the wiring in the cab is different. What do I do now? Is there a wiring diagram to cross the two different harness's. Please help
r or re?
Get the ECU and wiring harness for the 22re. You were really told wrong
The ECU or the wiring?
If both are swapped in you should be able to get it to run. Assuming the wiring and ecu after meant for an automatic transmission
