My Warn 8274 has stopped rewinding the cable, even though the motor turns over normally. At first, the brake was slipping under serious tension. Then it (the brake) was so weak it wouldn't even grip enough to coil the cable back onto the spool.
I just pulled the brake assembly and found one fiber disk clean and dry and the other oily and broken in one place (see pic), but would this explain a complete brake failure or do I need to look deeper?
Should have it all back together in about ten years.
