80 With Automatic Engine Starter!
Kuwait
I was just wondering if anyone out there has a manual transmission cruiser with automatic engine starter configured to it. Can it be done? Does a thing like that exist?
Since Kuwait is flat you don't have to put the car in gear to park it! You can just use the hand brake to keep it in place!
it is possible but you'll want to find an installer who's done it before. and you'll want to make sure you're not the kind of person who will forget when it's in gear...
I know who can do it but you'll need to come las vegas. ;)
I'm planning to be in Vegas for the SEMA Show in November, but unfortunately my cruiser won't be there with me!
Sounds like a plan!
There are relatively cheap multi featured alarms that allow remote start of the engine. Unfortunately the ones I've seen did not last more than 3 years before trouble came up.
Kalawang
I had a friend with a 5speed manual Acura install remote start, they disengaged the clutch wire or grounded it, I cant remember exactly. If you leave it in first gear you can stand next to the car and start it, the car will drive down the street next to you until you turn it off.
The remote starter in my manual Honda will only work for the next startup if I observe the following sequence:
1. Put gear in neutral
2. Pull hand brake
3. Turn off the ignition
Turning off the ignition does not kill the engine. It's only when I get out of the car and close the door will the engine cut and ready the alarm/remote starter for the next startup.
The sequence ensures that the hand brake is deployed and eliminates putting the car in gear. Opening the door without remotely starting the car disarms the starter.
Remote starters are a lifesaver for us folks here in Winterpeg.
ok, got the scoop today. he uses some fancy electromagnetic switches placed in strategic locations around the shifter and then mounts a donut shaped magnet on the shifter. if the shifter is in gear the switches sense the magnet and prevent the car from starting. he also puts a switch on the e-break as a precaution.
sounded like he does a few of these every year and hasn't had any trouble.
PM me in november so we can hook up for a cold beverage.
WOW! Seems real high tech! As for the PM, I will send you one when the time comes!
