80 Series won’t start
Los Angeles
hello everyone! I recently just bought my first land cruiser and it’s having trouble starting. I’ve looked over the forums and I still cannot find an answer. Hopefully you guys can help me out! Here are the details.
1991 80 series
-New spark plugs, and starter. Checked to see if there was a spark going on when I turn the key, there is one.
-There is gas coming through when cranking as well
-New Fuel pump(tested and works)
-NO CEL.
-Replaced EFI relay. Checked the fusible links and the EFI fuse. I used a multimeter and I am getting around 12v.
-Checked Air Flow Meter. I did this by taking it out, then checking if a CEL would pop up. When I took it out there was still NO cel, so this cannot be the problem correct?
I know because I do not have a CEL it should just be something electrical but I can’t seem to find the problem. Also, I checked the fuse box under the drivers side dash. Is it normal to not have a fuse for the “ECU-B” slot? It seems to be an empty spot, I can’t even plug in a fuse in there. I’m sorry if this problem was solved in a thread before, if it was, let me know and I’ll try and do some further research.
Checked off 1-3 on the chart for the no cel illuminated troubleshooting. So I guess what’s left is the ecu or “related wiring.”
Could the CEL bulb be out? Have you tried a jumper in the grey diagnostic box (passenger firewall) to pull any codes? Can't remember exactly which pins need to be shorted but when doing so your CEL will flash constantly if no codes.
Here's the procedure for pulling the codes:
Reading 3FE engine codes at home
Here's another similar thread that might help: 3FE No Start Issue
I don’t think the CEL bulb is out, I have a 91 and my pops has a 94. Coincidentally we have the same problem. No CEL, same problems, cranking but won’t turn over, and we checked all relays and fuses. Maybe the bulb is out but I don’t think that’s it. I’ll check the diagnostics box tomorrow to see if I get any codes!
I added the procedure above for pulling the codes. You can also put a jumper in the Diagnostic box to activate the fuel pump. Here's the instructions: 3FE fuel issue
In my experience with the 3FE, if you have spark and good fuel pressure (about 40psi), then it should start.
Oh perfect thank you! Don’t know why I couldn’t see those links the first time. I’ll check them out!
What about Step/test #4?
Yes also checked for a +12v on pin 8, which i had. Still no CEL. So my next guess would be either its ecu related. Possibly a Firing issue also. I have a spark and fuel is definitely pumping through so maybe there is an incorrect firing order occurring. Just my second guess, still going to do more research on this situation.
Also:
Searching for "CEL" in posts made by "jonheld" brings up all the times he's helped folks out in situations like this; whole lotta information.
Thank you for this information! Definitely will search for those posts
New starter;...New rebuilt starter? I may not have been done properly.
My starter had been acting up and left me dead in a walmart parking lot. Had a buddy pick me up and went to get a new-rebuilt. Tossed it in in the parking lot and no dice.(battery tested good as well). Returned that starter, went to Toyota bought new contacts and plunger installed in my original., but dead starter with my press and...Voila she started right up.
The contacts really need to be held in place with a press when installing them which I fear those rebuilt ones don't do.
How did you “check” the fusible links?
Rule #1: if you don’t have CEL when trying to start, replace the fusible links.
They are cheap. They get old and brittle.
I believe it was a brand new starter. I personally didn’t install it, the person I bought it from did about less than a month ago. He didn’t know much about land cruisers so when the car didn’t start he replaced the starter and spark plugs. When I checked it out it looked like everything was installed properly and looked like a decent starter. I’ll make sure to double check if that’s the problem though.
