80 series ride height
London
Evening,
I have installed an OME 2inch lift kit on my 80 series. Initially, it was sitting way too high at the rear, so changed the springs to 2860s (from 2863). Front has 850s.
To me the rear still sits a bit high but I haven’t fitted the arb bullbar (non winch) or the spare wheel underneath the rear.
Does this look right to you? Wheel arches to be fitted as well.
It’s got 33s on and don’t want to give it a big lifted look and want to keep it looking relatively stock with just a few upgrades.
She’s about to be painted.
Cheers
It looks as I'd expect it to with the springs you're using.
Thanks - what other springs would you recommend with this setup ( 1 - 2 inch lift) with not much added weight apart from bar?
It looks OK, but definitely more than 1 inch of lift. Only lower lift would be the so called stock height springs. The Rear of these 80s is higher than the front from the factory. What color will it get?
It’s got a 2inch lift
Going to repaint it in the original 3H4.
Pretty rare truck here in the uk as it’s manual, diff locks, 1HDFT 24v and 119k miles.
If you stripped the interior for paint, that's weight that will eventually bring the rear down more than the front. Additionally, once you have the requisite recovery gear in the back, a spare set of belts, hoses, a gallon of coolant, a few gallons of engine oil, the family dog and a spare head gasket - it all starts to even out.
I have the same lift, same springs, and all that stuff above and it looks level to me, from the drivers seat, anyway. Who cares what anybody else thinks?
Like @Devils Paw 80 said, the stock replacement springs are really the only shorter option (from OME at least). On a light truck, they will be around 1" or so lift over stock height. This thread has a little info about the stock height springs: Anyone using OME "stock height" springs? - https://forum.ih8mud.com/threads/anyone-using-ome-stock-height-springs.791554/
I think the 860/850 combo would only be considered 2" lift on a really heavy truck. Otherwise they are closer to 3" tall.
The rake is because it's unloaded. Once you add a spare tire, aftermarket swingout and other accessories it will level out. I added spring spacers "pucks" in the front to level mine out since I had heavy duty stiff springs even though I have a rear swing out bumper
who's did you use? I was looking at getting some from Delta as my truck still stink bugs but my bumper is light and has no option for a swingout
Rear swing out?
Avid offroad when they used to make them. They stopped taking orders because they were trying to catch up on their orders
The rear bumper looks similar to Highy's
Rear swing out?
Dissent
Urs must be the high clearance rear bumper. You can always carry the spare inside the cargo by using the Bellfab.
Or add front coil spacersFront Polyurethane Coil Spacer
Front Polyurethane Coil Spacer | 20mm for Lexus LX450 (1995-1997) – IRONMAN 4X4 America https://share.google/8Bx7tR34AGJi25994
Front Polyurethane Coil Spacer | 20mm for Lexus LX450 (1995-1997) – IRONMAN 4X4 America Front Polyurethane Coil Spacer | 20mm for Lexus LX450 (1995-1997) - https://share.google/8Bx7tR34AGJi25994
Those are quite a bit cheaper than the DVS setup. The spare is a pain in the ass for me. The Bellfab doesn't fit JDM cruisers, we have no provision for a third row. A few people have fabbed it up. And yes i ordered the extreme clearance bumper, I have zero need for a swingout and all the extra length and weight it adds.
Yep, I’m not going to be adding much weight on the back apart from spare tyre and prob a drawer system. Hopefully that will level the girl out
I dunno man. Having a swingout is pretty nice. You get used to it after awhile, and mine is a single-side (*Slee early edition w/centered spare). Two would be too many,
In what capacity is it nice vs it never being in my way?
On 2 of my 80s I have the swing outs (4x4labs and Avids). My pup goes with me everywhere and it is cumbersome opening the rear hatch.....but I like the way it looks with the spare tire and the jerrycans and posing in front of a coffee shop😎
Looks are always a reason to have something.
