80 series RHD driver side power window?
I have a RHD 80 series and was wondering if a LHD front passenger side power window motor would be interchangeable with a RHD front driver side window motor. Same location.
I am pretty sure that a left front window motor is the same part regardless of which side the driver sits on. The controls would be different. Double check part numbers to make sure.
Well, the door is on the other side of the steering wheel and the shift lever is in the wrong place.....
So yeah, the window motor will be the same. As @cruiserdan has stated in another post, the windows and doors are the same on all from 91-97 (does not include the rear lift gate assembly.)
Still, do like @inkpot suggested and check the Part Numbers. You can do that through the Toyota Parts | Toyota Online Parts | Genuine Toyota parts | Toyota Parts Online website.
Thanks
IIRC viewing from the rear of the 80, the left rear door regulator fits the front right door?
That may be a red herring but the guy who supplied me with a reg for a customer front right, swore it came from rear left and that would swap, and it did so perhaps another option?
Regards
Dave
I have a RHD 1991 HDJ81. When my driver's side window reaches the full up position using the automatic up function or holding up manually, the motor does not cut-off and instead chatters at the top. It is difficult to fully seat the window in the up position. Does anyone have ideas if this is a motor or a relay problem?
Thanks!
