Maveliciouse. When I'm going for a job as a secretary and need help with punctuation your my man I'll be sure to hit you up, and thanks for your abundant help on the topic in question. As for the rest of you fellas I do appreciate all the info you all have put forth. Thank you very much. So I'm building a nine-inch center with a pinion continuing on though the rear of the housing to drive a second diff, A.R.B. will be building a locker for it (and 2 others for the other diffs) so they will put the appropriate spider gears to match the spline, I will have to get the axles made to suit what hubs end up being used, the question about 80 series hubs came about because they are plentiful here and run disc brakes as at the moment mine is drum, hope this is a bit clearer of an explanation. I'm open to any suggestions or info on how some have done this with their own builds. THANKS again fallas.
