That's like a totally cool look, 'Carolina', Baby!
I guess that they come in various load capacity ratings, like OME. I've heard nothing but good things about the IronMan products.2 years old iron mans
The perspective on that pic seems to make it look worse than it is. The trailer all up hooked makes the rear of the cruiser sag 1", which is apparently well within "acceptable sag limits", but I'm no towing expert by any stretch. The rear of my 80 is loaded with the usual stuff (custom bumper with a 35" spare on one swing out, ladder on the other swing out (which currently has no basket for 2x 20l jugs), sleeping platform with 2 drawers full of recovery gear and misc camping stuff. Air bags are still a good idea, and those Sumitomo bump stops up front I'm considering, as I've bottomed out on the OEM ones lots.You found my post on them from 2008! Your trailer doesn't look heavy enough to cause that much squat
With that much gear and bumper weight, I understand the squat!The perspective on that pic seems to make it look worse than it is. The trailer all up hooked makes the rear of the cruiser sag 1", which is apparently well within "acceptable sag limits", but I'm no towing expert by any stretch. The rear of my 80 is loaded with the usual stuff (custom bumper with a 35" spare on one swing out, ladder on the other swing out (which currently has no basket for 2x 20l jugs), sleeping platform with 2 drawers full of recovery gear and misc camping stuff. Air bags are still a good idea, and those Sumitomo bump stops up front I'm considering, as I've bottomed out on the OEM ones lots.
That’s a lot of added weight. So maybe you’d be happy with air bags. How much tongue weight does the trailer add?The perspective on that pic seems to make it look worse than it is. The trailer all up hooked makes the rear of the cruiser sag 1", which is apparently well within "acceptable sag limits", but I'm no towing expert by any stretch. The rear of my 80 is loaded with the usual stuff (custom bumper with a 35" spare on one swing out, ladder on the other swing out (which currently has no basket for 2x 20l jugs), sleeping platform with 2 drawers full of recovery gear and misc camping stuff. Air bags are still a good idea, and those Sumitomo bump stops up front I'm considering, as I've bottomed out on the OEM ones lots.
Good call. Do any of you guys with 80 diesels install front airbags to compensate for bumper/winch weight etc?I've ordered some Air Lift bags. Quite a few write ups and installs on them in the 80 series section here with great results. These are there 1000 series and they fit inside the coils, they are not fixed at top or bottom. They will seat eventually at the bottom and work by maintaining pressure on the inside diameter of the coils.
Air Lift 1000 Air Spring Kit - 60755 | Air Lift Company
Air Suspension and Air Managementwww.airliftcompany.com
My 80 is set up pretty much like everyone else's in the club I think. Gregs is the only one I can think of that has the weight more centralized as he has removed his second row seats for storage solutions.
The trailer is rated at 2200 lbs dry, 3500 GVW, with a 300 lbs tongue weight.
Generally it's a non issue up front, and I havent heard of any. But while I was researching this I stumbled across these Timbren bump stop options. I'm pondering the front ones as I've bottomed my front out numerous times (stock bump stops) on a 2" Iron Man lift when doing something silly. Timbren SES Suspension Enhancement System SKU# TOFLC1A - Front Kit - https://timbren.com/en-ca/products/toflc1a-toyota-land-cruiser-70-series-80-lexus-lx450-1990-present-front-kitGood call. Do any of you guys with 80 diesels install front airbags to compensate for bumper/winch weight etc?
Is it considered a solution to handling or would you think it's a bad idea?
They do..mostly. It seems the very early models, like mine, only have the bump stops inside the coils. Later Toyota added additional frame mounted ones, but mine doesnt have the bolts holes in the frame.That's why I came up with using the SumoSprings on the 60. I got the idea from a participant running the
King of the Hammers. He had them on all 4 corners, and like him I found they really soften the blow of heavy
nose dives. I'm just not sure they work on the front coil trucks.
