80 Series Purchase - what to look for
Thanks for all the comments.
Not looking to do many mods if any, to be honest its such a good truck as it is that apart from a few cosmetic things - Vent visors, bonnet (Hood) protector, rear spoiler and maybe a new set of side steps as the current ones are bent there is not much it needs, Anyway I want to spend the folding stuff on getting it 100% as it should be.
List of things to be done.
1. Fix the diesel leak on the lift pump pipe.
2. All for tie rod ends to be replaced.
3. Front bush kit (maybe go for polybushes)
4. Rear bush kit
5. Fit a set of front fog lamps
6. Get a replacement tool kit (on order)
7. Fit my Car phone kit (Parrot bluetooth)
8. Fit my GPS antenna and the holder for my Ipaq
9. Decent set of tyres - BFG A/Ts
10. Get the wheels professionally refurbed and get some centre caps or I might decide to replace them with a set of all black steel spokes
11. Clay the paintwork and then give it a good polish and sealant.
etc. etc. etc. etc
Cheers
Sweet Ride !!
I want that motor.
I am assuming that "clay" is wax, what are "polybushes" ?
Clay is something you can do to the paint while detailing, removes all impurities without damaging paintwork. You use a clay bar and a lubricant and rub the paintwork, the clay brings up a really nice gloss that even paint restorers don't give you, then you can wax and topcoat on top.
It's been quite big in the US for a while but we're only getting it in the UK now recently.
Polybushes are replacement bushes for the suspension components mad of polyurethane rather than rubber, give you a much tighter handling vehicle and last a lot longer. Make it a little bit harsher sometimes but generally much better than stock because they give less. You only then use the sprung components of the suspension (springs and shocks) to give you flexibility. Normally with rubber bushes, after a while the bushes have quite a lot of give in them as the rubber breaks down, means that you don't get 100% accurate location of the suspension components such as the trailing links, sway bars, shock mounts etc.
Cheers
Andy
I don't believe there are special allowances required to register and operate a rhd vehicle in the states. I have a '67 land rover with rhd registered and driven in USA. When I fisrt went to get it inspected for regisitration (annual in MA) there was a big discussion about what side to put the sticker on. there were a few guys standing around talking about it and the manager came out. He said what's the problem? they started explaining the whol confounded delimma and he pointed at a corner and said put it there and get back to work.
When I pulled up to the inpsection bay the tech said.....registration and $20, followed by a single question....Does everything work? I siad yes they took my money, I took a stacker and drove away.
harveya,
Nice rig!
Is that the headlight-control dial I see on the right side of the steering next to the mirror adj. switch or is it something else? If so, how do you like it? If that's what it is, then another option that many (most?) people did not get outside of Europe, I think.
Anyway, congrats!
Mot
mot said:
harveya,
Nice rig!
Anyway, congrats!
Mot
Mot.
Yep that's the headlamp adjuster, haven't used it yet however I have used it on previous vehicles and it is very usefull if you are carrying a lot in the back. Think it is now a legal requirement certainly on big motors that can carry 7 or 8 passengers. Even the UK 4Runners have them whereas my Hilux Surf (Japanese 4Runner) doesn't.
Cheers
Andy
4. Rear bush kit
etc. etc. etc. etc
Cheers
Harveya,
Looks like you and I have much the same rig. Yours is probably newer as my furniture is much simpler and not anywhere near as luxurious as yours. My engine is a 1HD-T.
I would suggest you change all fluids immediatly as you get the vehicle, and in doing so save samples of the old fluids into some small glass jars so you can check for solid particles after the fluids settle. I think it's also a good idea to change the timing belt immediatly unless you have confidence that the former owner treated the car properly.
I'm also experiencing a small deisel leak at my injector pump but it's so small, also about a teaspoon, I'm waiting for some energy before I decide to deal with it. I would much be interested if you post your experience as you deal with yours.
I've left my wheels without center caps, I don't like them, and it looks to me as if you have the slight forward lean, or nose droop, that I also have. It can be eliminated but I think only worth doing if you needed the very slight improvement for angle of attack. Bigger tires or a small suspension lift will do much more for that in a cost effective manner.
Would it be too surprising if I say that I think you bought yourself a very good car ?
Kalawang
Kalawang said:
Harveya,
Kalawang
Thanks, I think I got a good one too.
I've got a full service on my list probably for next week although the engine oil is clean and I have the receipt for a service done about 2 months ago just before I got it. However I've always felt that I prefer to do these jobs myself as I know what has been done.
I'm not going to touch the brake fluid however as It looks good and with brakes I don't touch unless it needs it (apart from doing a full replacement every 50K miles however I know this has been done twice on the vehicle since new so It's OK for now.
I'll also leave the coolant alone as the radiator was changed only about 5000 miles ago and new Toyota Red coolant added.
However Oil, filter, transfer case, transmission, diffs are all up for a change - especially as the front axle and transfer case are a bit noisy - although they are quietening down since driving it, think it hadn't had a decent run for a while.
Yep it certainly does have the rear up stance, but I'll leave that for now and majbe change the front and rear springs (they don't cost much here) when I do the suspension bushes.
I think the 1HD-T engine is great, loads of low down torque and it pulls like a train from about 1500 rpm all the way past 3800 rpm where it loses a bit of steam. Accelerating from 70mph is great, box doesn't even have to change down.
I've found that the leak is actually an oil leak from the vacuum pump not the injector pump - the guy who sold it to me said it was a fuel lift pump but having looked at the manual, there is no lift pump and the thing where it is leaking is actually the vacuum pump. It's coming from one of the banjo bolts, so I'll have to remove and replace the brass washers - pretty easy job I think. Injector pumps are more tricky, top seal on all toyota diesel pumps seem to go after a while.
I'm still thinking of replacing the Toyota alloys with some 8x16 steel spokes in black or some chrome and black modulars - although I do like the look of the spoked rock crawler type wheels.
I will be replacing the timing belt as it's an easy job - 30 minutes tops on the 1HD-T. Having changed timing belts 5 times on a 2LTE (2.4TD Toyota Diesel) the 1HD-T is a doddle. The 2.4 requires you to strip out the front of the engine and remove the bottom crankshaft pulley. ON the LC it's a few clips to remove the cover, pull off the belt, take back the slack on the tensioner, refit with all the timing marks set, release the tensioner, rotate engine a couple of times, tighten tensioner, cover on - Job done.
Where was you Cruiser originally built for, the Japanese and asian units tend to have a different specification than the UK and US ones. They never have leather although some have suede, they never have electric seats (except lumbar support) but they do often have winches, lifts, clinometers etc...
Cheers
Andy
I didn't do any engine rotating when I replaced my T-belt, I actually took precautions that the engine not be rotated or move in any way as I didn't know what I was doing. I thought it the safest path. I also failed to re-set the T-Belt alarm. Rather shocking to see that amber alarm come on at night in the midst of a long journey.
The business with the tie rod ends is something you can feel as you use the car, so I don't think it all that urgent. However I feel your hoses should have a good looking at for age and loss of firmness. You might also benefit from giving a good look at the fan belts too.
My LC was built for the Japanese and I aquired it as junk. Seats are fabric covered, which is good in hot places, and I had to toss out the stereo because the Japanese work with different standards and frequencies. I haven't spent a lot on my car. Just maintenance both preventive and need. I did lower the car. It came with a 4" lift that I couldn't live with after a year and a half, so I changed the springs for a 2" lift. I don't do all that many river crossings anyway, except in the city.
Kalawang
Cruisin'Carolina said:
Now I get it....
Bushes=Bushings
Still would like to know more about the clay, though!
Crusin' check the FAQ, there is a thread there with alot of opinions on washing, waxing, and general care for your truck. Clay is covered in it.
Reffug,
The FAQ is wonderfull. So many questions answered before being asked.
Congrats on a great FAQ.
Kalawang
Kalawang said:
Reffug,
Kalawang
That is the whole point...now to get everyone to look there first :flipoff2:
Kalawang,
Also use the search feature. It is another great way to find out information that has been covered, without having to ask.
That is service....providing answers before you ask the questions! :D
harveya,
Wow! Sweeeeeet rig.
No roofrack + no rear wind deflector = NO RUST! :flipoff2:
Harveyea,
I am totally jealous! I WISH Toyota sold those here in the US. The only thing better than a locked LC with no factory roof rack is a locked LC with no factory roof rack and a TURBO DIESEL.
Congrats! :beer:
97 Land Bruiser said:
Harveyea,
Congrats! :beer:
Factory roof rack would be no good for me anyway as the Cruiser is that tall that with a rack I wouldn't be able to get into my local Multi Story Car park (parking garage). Just going to get a couple of the roof bars that mount on the rain gutter if I need to carry anything on the roof.
This car is a keeper now, don't intend to change it out for at least 10 to 15 years so I can do things slowly. That's the main reason for a Cruiser, there iis very little else out there that has the build quality and the tough components that the Cruiser has.
Kalawang - I presume the T/Belt light on these is reset via the dashboard - remove the plug, press the reset button with a long thin screwdriver.
Interesting that you should mention the belts, thought I'd leave them for a while however th power steering one started slipping and squealing so I guess I'll have to change them pretty soon. Guess the hoses are a good idea too.
Cheers
Andy
Harveya,
Your car is definitely newer than mine. I have the old PS box that's directly engine driven rather than the new ones run on a fan belt. As to the hoses, I consider that defensive maintenance as I'm not sure I would detect their deterioration while driving and it's such a nuisance to have them give in the midst of a journey.
I mentioned the fan belts because they're easy to inspect, easy to replace and such a problem if they give when you don't have the time or inclination to deal with them. My old ones were still in good condition after three years of use so I stored them in a panel at the back of the car for emergency use.
Kalawang
