- Joined
- Mar 27, 2013
- Threads
- 1
- Messages
- 1
Hi there, I have an 80 series 91 GXL Landcruiser 1hdt engine, It is a full time 4wd which is stock apart from a 2inch suspension lift, running 31 inch wheels. We have done 500,000 k's and it is a little tired but very well maintained in the last month or two we have had brakes checked and re done, all wheel bearings replaced, two front unijoints replaced, front swivel hubs/bearings replaced cvs checked and re packed 4 new tyers wheel alignment balance and the chassis under steering box plated and welded (found by audible clunking on turning) Now we have a new noise which is progressively getting worse. The noise occurs when driving at any speed usually at the coasting point of a gear change it sounds like metal on metal and comes from the front end of car i do not feel any shuddering in the clutch pedal during the gear change. It is no different on turning or straight and is no different with diff lock on or off. Have taken it to 4 wd specialist who are scratching their heads also - suggestion is that it is the transfer case - has anyone had this experience? Am set for replacing transfer case after easter but am concerned this is not a solid diagnosis rather a well its the next thing to fix. HELP.....
