The car is a 96 fzj80, this connector is located just forward of the drivers side rear wheelwell, right in front of the body mount. The connector pictured is the connector you disengage when changing your fuel filter in order to let the pressure leak out of the system, thus enabling the removal of the fuel filter.
Question: Does anyone know what the unused white pigtail is used for? If so, what are the wires, meaning what do they run to? hot? ground? etc?
Also, if anyone has these two connectors on hand, I need this assembly cut out of the harness with a few inches of wire left on each side. PM me if you can help.
2nd Also, if anybody knows where to get these connectors wholesale I would appreciate it. I have already checked with Cdan and the pricing is too expensive (not his fault) from toyota. I am looking for the grey connectors and the silver "snap" leads that go into the connectors to lock the wire in place.
thanks,
Noah
thanks,
Noah
