80 Series Center Console Coin Slots
Since you mentioned seat heaters, where did you wire yours in. I have a plethora of placed to wire in for 12V. But where is the sweet spot that is most commonly used?
Mine were wired to the battery by the previous owner, but not hooked up.
All I did was to hook all the connections up.
I hate an incomplete hijack...
» if you have an 80 series with factory leather interior, you'll find two unused connector housings in the right and left body harnesses, under the console, immediately below the forwardmost coin slots. Both connector housings mate with the respective OEM seat switches, designed for those coin slots.
» if you have an 80 series with factory cloth interior, you'll find one unused connector housing in the left side body harness, under the console, immediately below the forwardmost coin slots; the passenger seat just doesn't get any love.
Oddly enough, there are power seat connectors below both seats, regardless of which interior you got from Toyota.
I haven't checked, because I don't have one to play with, but rumor has it the LX450 doesn't have factory connectors wired into the body harness, either the dash harness or the RH/LH body harnesses. Odd.
Yes.
They were there.
Can confirm on the leather seat version. I pressed the circuits into service to supply power for my Audi seat heaters using VW controllers mounted in (to bring it full circle) two of the coin holder slots.
