80 Series Caster Correction Drop Brackets
Fayetteville, Ark
I bought the 3" Man A Fre lift and decided not to use the drop brackets that came with it, because I don't like how low they hang down. I've heard good things about these, so, if you aren't worried about dragging them on rocks, it would be a good choice. I ended up using slee's caster plates with my lift, and needed a DC drive shaft ($$$) to fix the vibrations. You may be able to save $$ by using these drop brackets, as the people that I've seen that use them didn't need the DC drive shaft.
These are also much easier to install than the CC bushings (no press needed, etc).
They are brand new, never installed, and only taken out of the box to take a picture.
They list for $255 on their website (FRAB-3) which seems kinda expensive:
http://www.man-a-fre.com/pa/80seriescastercorrection.htm
I'd like to get $150+shipping, or best offer.
Shipping should be around $20. I can get you exact $$ using UPS calculator, if needed.
I'll jump on too.
