80 needing a engine swap out
Catonsville
Hey Guys,
I looking to get an opinion. I own a 100 series but recently found an low mileage 80 series in PA with 120K on the clock and
an engine that has overheated due to a snapped serpentine belt. He wants 3K for it. Given the snapped belt, i'm thinking this
car has had very little maintenance on it. I might be able to pick up another decent engine for 2K but am still
hesitating. No rust, but it has been sitting for years. Should i go for it?
It is a 1995. I will at least go and see it, but best case i think i'll be replacing a more than just the engine.
His reason for overheating isn't a reason that would be possible unless it had a swapped motor. It could just need cooling system work but it could also need a head job.
Depending on condition(rust?), it might be a diamond in the rough or it could just be rough. I think it's safe to say that it's unlikely that the person selling it has any clue how it works or what might be wrong with it, which means you'll need to do some sleuthing to figure it out.
120K is low miles though and interior and body condition, etc should reflect that.
LOL, I guess you're new to the 80 forum. Overheated engines are a hot topic here, no pun intended. Often a simple head job is all they'll need.
If the stock motor is in it, it’s a 1FZ that was identical ‘95-‘97.
It’s a timing chain driven DOHC, and cooling jacket to #6 cyl is where they like to blow the headgasket.
If the owner drained the fluids before parking, the motor may be salvageable with a new HG.
If it sat with coolant in the #6 cyl & in the crankcase, then yeah - rust in the bore & down in the lowest part of the crankcase.
I’d really have to like the color combo & condition of it if I was to buy any blown 120K 80 for $3K. And it really would have to be rust-free.
But if you do, a swap to a 2UZ or something else like a diesel or LSx motor would make for a fun rig.
Yeah, lol, i rarely venture over from the 100 forums.
I've had the "privilege" of changing out many heads on the 4L Ford straight sixes, so i'm expecting much of the same with the 1FZ. My biggest concern is that it's more than just the head.
Agreed, color combo and condition will be a big aspect. But there is no chance the owner drained after blowing the head, guy has no idea, so that fluid has been sitting there for years.... I'm Australian so i like the idea of the diesel....
I thought about it more and it could be as simple as just needing a new set of belts for the water pump. People throw around the term "serpentine belt" a lot because it sounds like something a mechanic would say and they see a belt wrapped around a bunch of stuff and just spit that out.
Did you say what color it is? I missed that.
As for the idea of a swap, you would probably be further ahead if you had your mates back home look around for a diesel 80 in Oz and having them ship it to you. Making a gasser, US spec 80 into a diesel, any diesel, is not a cheap proposition. Way, way cheaper to just toss in a used or brand new short block with all new trimmings 1FZ-FE. You would have to get used to driving on the other side of the road, but you are probably further ahead on that then most Americans. Probably no more drive thru at In and Out Burger though. ;)
I've only had the 100 for a few months so i'm not super keen on dumping a whole lot of cash into this rig.
I did try driving some right hand drive cars here and i didn't like one bit, on the trail, sure it doesn't make any difference but on the road it takes a lot of getting used to....
Went to have a look at the car, rust way too much rust. For a 80 series with such low miles it looked beaten, never serviced, just
generally neglected.
