80 low gearing low enough??
"the whale's vagina", CA
I am looking into selling the 40 and buying an 80 for all around wheeling and family trips.
I would like to have it with 35 inch mud tires, 4 or 6 inch lift (whatever needed to fit 35's). My concern is low gearing. I plan to regear the diffs to whatever needed but want to still be able to run on the freeway at 70/75 mph. I have seen some gears from marks 4wd in Australia but they are expensive. I am wondering if others that take their 80's rockcrawling (rubicon / dusy, etc) feel that their 80's are low geared enough for the trails they take? Does your 80 leave you wanting lower gears or ? Ideally I would want to be to 100:1 range but I know with a torque converter on the auto tranny you can basically double your crawl ratio. Is it possible to get to 50 or 60:1??
the equation I use for my fj40: Tranny x TC x Ring and Pinion = end crawl ratio.
If anyone can help me with plugging in the correct above #'s so I could figure out what my end crawl ratio would be, I would appreciate it.
Also, the equation I use to determine highway speed:
MPH X Ring and Pinion X Tranny overdrive X Transfercase Ratio X 336 (divided by) / tire diameter
thanks for the help and any opinions from the 80's gurus out there, I plan to eventually join the club! :)
Noah
Just from experience I can tell you that if you want to run 35s you'll want to use 4.88 gearing. With those, you can still run 80 mph easily.
If you stay with 33s, you can get away with the factory gearing.
40s and 80s compliment each other very well. You should keep the 40.
Edit-I looked at your ROTW. You have a sweet ride. Bring that to Rubithon this coming year before you decide to sell. You'd be welcome on the wagon run which I lead on the Wednesday of Rubithon weekend. We had several 40s last year including mine!
thanks Drew, it will probably be awhile till I sell it, just because the market sucks right now. I have made up my mind though, it will be sold, just doesn't fit my needs anymore and honestly I have had the car since I was 16 (now 35) and just want a change of pace. The way I see it, a well built 80 can go almost anywhere (rubicon/dusy/desert, local big bear trails) and take my family and me in comfort on long road trips, that's what I need out of a toy truck right now. I plan to build it right, and it won't be a daily driver, just an escape hatch for weekends and vacations.
on topic: has anyone heard good/bad things about the marks 4wd gear set they sell out of austrailia? expensive, not sure it is worth a 25% reduction. George @ valley hybrids told me he has heard they are noisy?
Double footing the pedals on a re-gear'd 80 with the stock t-case gears is pretty low; low enough. Though, after driving anything with a crawler box or doubler or double cases I do feel that lower would be better, but not necessary in the 80.
I--along with a fair amount of other people--get by on stock gearing and 35's just fine. It's not ideal, but it's not horrible either. I probably won't regear due to the cost. After driving it (including up the highest pass on I-5 loaded with 4 people and gear for a week and a half) it's not a high priority for me.
And for lift, you only need 2.5" if you want to be able to run 315's with some rubbing. 3.5" of lift allows you to run 315's with essentially zero rubbing.
I agree, 35s on stock is just fine...just wait till you re-gear though.
And 35s on 2.5" is the same as 35s on 3.5" if your bumpstops and caster correction are the same.
Stock gearing is not fine with 35s if you run harder steeper trails.
It's OK on the road, and I've seen NorCalDoug beat his junk through the Rubicon more than once. But.....
I've also seen several occasions, especially on Dusy-Ershim, where the too high gearing causes the torque converter to stall, resulting in a stuck truck and an almost immediate transmission overheat. I've seen this on 2 different 80s, both with 35s and stock gears. At best you can back up and retry, and at worst, you need to wait and let the tranny cool off before trying again. So in my biased view, it's possible to run stock gears and 35s, but it isn' "fine". It's a crappy compromise. The other side of this is that 33 and stock 4.10s work pretty well. So maybe the big tires are what isn't needed.
I would say the Mark's 80 series gearing is an unknown. Is anyone in the US running them? If so, I'd like to know their experience. The gears for the split case have a rep for being noisy.
I appreciate everyones opinions, keep em coming. I would like to figure out what the stock end gearing would be for an 80 w/35's and 4.88 gears. I plan to regear for sure and I plan to run 35 inch muds for sure. Can anyone help me with the equations I posted above, I need the #'s to plug in there to do the math. I figure if I can get to 50:1 or close to it, then I should be ok, as most people have told me that with an auto you can effectively take that ratio and double it. FYI, I do not want to run the hammers, but would like to do the rubicon and dusy and I enjoy going slow and low and finessing things if possible.
thanks!
Noah
are 315's the same size as 35's MTR's ??
doing some calculations and am wondering, what is the ideal RPM at 75 mph for these trucks?? I would guess you would want to get it close as possible to what it is at stock. So, the question is: can anyone tell me what end RPM range I should shoot for when travelling 75mph on the freeway? What is the stock RPM range at 75mph?
thanks,
Noah
thanks,
Noah
I read one post where a guy used his scangauge to calculate the ideal RPM for gas milage. According to that post, 2k RPM was ideal.
However, to run on the freeway at (around) 2k RPM will mean 35's and stock gearing (or a similar ratio), which may be too high for some trails.
