80 leak down test + compression test
Somewhere
Hello,
I am buying a 1997 Land Cruiser 80 with 240k miles, I accepted paying for the leak down and compression tests. The compression is fine but the leak down worries me a little bit. Can I have some advice from local LC gurus ?
Here is the email from technicians doing the work:
PERFORMED COMPRESSION TEST RESULTS: CYL 1-175, #2-170, #3-170, #4-172, #5-178, #6-185 ALL READINGS ARE WITHIN PSI .
PERFORMED CYL LEAK DOWN % TEST RESULTS: #1-20% RINGS, #2-27% RINGS, #3-26% RINGS, #4-38% RINGS, #5-34% RINGS, #6 15%RINGS. LEAKDOWN IS NOT INDICATIVE OF A LEAKING HEADGASKET BUT RATHER SOME LEAKDOWN INTO THE CRANKCASE PAST THE RINGS AND CAN BE CONSIDERED TYPICAL DUE TO MILEAGE. NOT AN ISSUE AS CAN BE SEEN IN THE STRONG COMPRESSION #’S OF THE FIRST TEST.
PERFORMED CYL BLOCK LEAK TEST, RESULTS: PASSED NO HYDROCARBONS IN THE COOLING SYSTEM. (See pictures)
CONCLUSION IS NORMAL WEAR OF THE TIME AND MILAGE THAT IS ON THE VEHICLE AND NO INDICATION OF ANY KIND THAT THE HEADGASKET IS BAD. IT ALSO VISUALLY APPEARS THAT MOST LIKELY THE HEADGASKET HAS BEEN REPLACED SOMETIME IN THE PAST ON THIS VEHICLE.
Thanks,
Jorge
well, as discussed on MUD before, IMHO the absolute numbers on the leakdown are pretty much meaningless and not comparable between different devices, and accurate numbers are also hard to generate, so I personally would not pay too much attention to the absolute values. The relative differences could be more interesting though, and there is some notable difference there. Sorry to say I don't know what to make of that, except saying that some rings/valves may leak more than others. IOW, 38% means nothing to me without knowing more, but of course to the tech if he has some actual comparisons to use, it may. It surely does not mean "38% bad" or anything like that, if you were worried about that.
Yes, the compression numbers seem good, with the 6 a bit of an outlier (for leakdown too), but for the better. Was this test done cold or warm?
There is not enough info there really to make sense of those numbers. Warm/cold, dry/wet, what devices, noise generated, etc? Not the most rigorous report...
Unfortunately the report is all I got and nothing more. I could call the technician tomorrow and find out more, just to make a list of questions:
* leakdown done wet or dry
* leakdown done war or cold
* what device used for leakdown
I am not sure what you mean by "noise generated" .
Thanks for your help.
Regards,
Jorge
The shop told you all was well and good. If the it runs well, does not smoke and the spark plugs look normal, what's the question?
I wouldn't give the guy the third degree or he'll become defensive, but if so inclined you could ask for a bit more of an interpretation of the results and what those numbers mean for him. Basically, the rationale as to why he seems to disregard the results of the leakdown test he just did.
The wet part referred to putting oil in the cylinder to see if the numbers change. By noise, I meant you can listen to the exhaust or intake to try and identify a leak through the valves. All that may be beyond what his standard leakdown test is, though.
It seems like you asked him to check primarily for headgasket leaks with that leakdown test, but I suspect a leakdown test may not reveal minor ones. He did do sniffing it seems, though.
Just a question , how do you determine that the leak is actually going down the crankshaft pass the rings ? I got it that you can listen to exhaust or intake or take a look into radiator or coolant reservoir for bubbles but not sure where you should hear the leak in case of bad rings.
Buy it Jorge, and come join us at Tuttle creek next weekend (23-25th). Sorry I haven't been available to help you with your search! Been crazy busy with work, wife, baby, and prepping my rig for Tuttle.
Once you get to know the group, you'll have plenty of resources to help along the way.
I don't think you could have hoped for better results, honestly. If you're happy with the shape of the rest of the cruiser, take the plunge!
  • Like
Reactions: SAS
well, one way is with the oil test that I mentioned. If the compression increases and/or the leaking decreases, it's likely the rings.
Here is the response from dealership:
can I get more details regarding the leak down test. There is a huge difference between cylinders 4,5 and the rest of them, can you please share following information:
* how exactly was the leak down test done. First put the measured individual cylinder at top dead center, attach the cylinder leakage tool to that cylinder’s spark plug hole, pressurize to 90psi, then through the tool it tell you percentage of leakage on that cylinder.
* what device was used for leak down test cylinder leak down test tool. cylinder leak down test tool.
* did you verify where the leak is going (exhaust, intake, oil cap , radiator) (use stethoscope to determine where leak is coming from or look for bubbles in the coolant.) He determined the leak down was not coming through the radiator (no bubbles). The leak was coming past the rings into the crankcase. See the notes on the leakdown test - he specified where the leak was coming from on each individual cylinder. They were all “rings”. Again the overall compression is still strong so rather typical for the mileage in our opinion.
150 totall labor with 49 parts (had to buy the kit for exhaust leak into coolant tester).
Jorge
