80 headlight, JDM VS N.american, same?
hi guys,
so new years (i'm assuming) some drunken a$$hats decide to use my rig as target practice for throwing shampagne and wine bottles out of their balcony window. i noticed it 2 days later. had to make a claim since my deductible is less than the actual repair and it doesn't affect my rating/record b/c it's classified as vandalism. anyway, so i went ahead with the fix which involves popping some dents out and repainting driver side front panel and hood and replacing the drivers side headlight assembly. it was a little tricky for the shop to figure out the part, but was able to source out a headlamp assembly from california/Toyota. we double checked that the part was for an 80 with a headlight washer. it finally arrives, the truck is painted, but they say the part won't fit! i thought they were identical pieces? why would it not fit? anyway, they're gonna check tomorrow, if i need my vehicle they can just reinstall the old broken one, just cracked, works fine till they said, they can get the right one from europe??
make any sense? preciate any help/advice. or if anyone has the right part number, that'd be great.
romey
. . . guess i'm lucky they didn't get teh windshield or my sunroof! **ckers!
is this not an identical set up to the FJ80's? they checked for 91 toyota landcruiser and i heard them say "FJ80" and i confirmed it's the same vehicle...
I checked a 1991 HDJ81 against my own NA-spec 1991 on ToyoDIY.com, the part #'s do not match.
PM me your VIN, I can double check it if you want.
Hang on a second... Your truck is RHD. Also looks like you have the inner fog setup.
There were no RHD 80's sold in the states. The "driver's side" headlamp they found was most likely from a LHD 80.
You need to search locally for a Euro-spec RHD driver's side headlamp with the inner fog lamp.
shoot, f'got about the fog lamp, but just assumed that you guys got it too. i understand diesel rhd's weren't sold in the US, and for sure they got the part for a lhd 91 80. guess i'll tell the shop that in the morning. you'd think the lamps would be designed teh same way, with just a different bulb for the fog's...? i thought the grills were differnt too, but they look identical...
. . . i hope the ins. company doesn't get irked by this if the lamp ends up costing way more. there are plenty of jdm 80's and parts sources in canada so i hope it won't take long.
Not really... Different housing/lens combinations for different markets.
H4/H1 (Euro), H4/Fog (your setup), 9005/9006 (USDOT), sealed beams (base model)....the list goes on to include Euro and USDOT beam patterns.
yeah, gotcha. not to mention the 4 square light combo the south american's and aussies got.
Yeah, those are the sealed beams I referred to. :D
thanks for the quick help and reference!
Any time. I hope you get it figured out soon! I'd hate to come out to my truck to find really big dents in it... Oh, wait...
RHD and LHD lamps throw different light patterns. If you pay attention you will notice that the light goes more to the passenger side of the vehicle and does not go much past straight ahead of the driver.
Because of this RHD lamps will shed light into on comming LHD traffic and vice-versa. This is why they are illegal in opposite markets.
the US 9005/9006 FJ80/FZJ80 assemblies fit but you don't have the wiring harness for it; but, you can make an adapter
your harness has plugs for Euro H4/H1 and JDM H4/fog
I've been told that the LX450 does not fit; haven't tried myslef
If you are looking for a replacement for exactly what you have (JDM spec H4 w/H1 fog) we are parting an HDJ81 that still has the JDM headlamps in it.
yeah, i know about the light patterns too, been curious as to how much light spilled out to oncoming traffic, guess i can find that out soon..
pm sent 70sguys.
Mot actually had a thread where he had posted pictures of both LHD and RHD E-Code beam patterns in his cruiser and they are posted below.
E-Code pattern for people who drive on the right side of the road, pattern cutoff rises to the right to illuminate street signs, pedestrians etc.:
attachment.php
E-Code pattern for people who drive on the left side of the road, pattern cutoff rises to the left to illuminate street signs, pedestrians etc.:
attachment.php
Obviously if you have the wrong pattern lens for your location the pattern cutoff rising is not going to be illuminating the side of the road but the faces of oncoming traffic. Notwithstanding the legalities of the JDM beam pattern (CMVSS 108.1 allows E-Code lamps but for LHD beam patterns only for obvious reasons) with the RHD beam pattern you fail to both illuminate the side of the road and pedistrians, signs etc. but also throw a good amount of light into oncoming traffic.
4c3hJ
Haven't read everything said here, but could it be possible that the new light you got is for the '95-'97 80 series (Yours is '90-'94)?
And I guess you would want to clarify why the new light "won't fit".
It might be possible that the light itself mounts using all (or at least most) of the mounting bolts, but one of the mounting points for the grille does not fit if it's the newer light on the old "TOYOTA" grille.
It is hard to imagine the light not physically mounting.
So, if it mounts, but does not use all of the mounting holes and the radiator grille fits, I would not worry about it so much, as long as it's not secure and it wiggles while the vehicle is in operation.
Of course, if the light pattern of the new light is for RHD, then that might cause a problem with your local police, etc...
I thought ATEB(sp) or Outback sold both/either the Euro-spec/LHD headlight replacement (Not sure if it's factory Toyota or someone like DEPO) and/or the quad headlight/HID kit.
Sorry if I'm not much help.
I'd be curious to see what the new light looks like and why/how it wouldn't fit.
GOOD LUCK!!
