ah. i dont think thats ever happened
Slippage typically affects acceleration. The engine will rev higher than normal, but accelerate slowly.
it doesnt slip at other times. also this has only happened twice and both times i was depending on following someone whod already started off so i was primarily concerned about getting started as fast as possible so i a lot of its not really clear. next time ill try to be as scientific as possible.
AT fluid level requires the engine running and hot right?
sounds like a solinoid is bad. fairly common on the a442f. read through the FSM trouble shooting.
... AT fluid level requires the engine running and hot right?
.As a possible next step, consider running a gentle cleaner through the AT and then changing the fluid to a high quality synthetic ATF, like Red Line D4ATF.
Auto-RX transmission cleaner: Transmission Trouble Shifting Gears, Auto-Rx Cleans Internal Engine Sludge Motorcycle Power Steering Differential Diesels, Stop Leaky Seals, Oil Burning, Better Gas Mileage, Increase MPG
