80 gears
DC
Website
www.instagram.com
when i start my truck and put it in gear, on very rare occasion (twice in the last month or two, never did it before)it will act like i have the transfer case and transmission in low, but everythings normal, the handbrakes off, etc. i have to shift both sticks around for a minute and eventually it will fix itself. anyone know whats goin on?
What exactly do you mean "act like it's in low"? You will know when the transfer case is in Low gear, first gear tops out at about 10 MPH.
Can you elaborate more on 'it will act like i have the transfer case and transmission in low'?
EDIT: punk Lka :flipoff2:
lots of throttle. not lots of speed.
:confused: Explain. For example "When I hit the throttle, <blank> happens."
We aren't trying to be rude, we just need more info...
@Spike- Where's B when you need him? :lol:
@Spike again- :flipoff2:
If you aren't getting power to one of your axles that might explain 'lots of throttle. not lots of speed'. You would be running on the viscous coupler, which would slip a lot until it heats up. If that's the case, driving it like that is NOT good for it.
EDIT: Take THAT, Lka. :flipoff2:
Does the engine rev high, or does it feel like there is no power?
Be specific. ;)
at about 2500-3000 rpm its not even triggering the speedo. i dont really know a whole lot about it because its literally happened twice in 140K miles, and the first one was about two or three weeks ago. essentially i think its got to do with something thats not the engine, because that responds normally
no, it definitely drives all the wheels, at least after i fix it, which is after ive run from P to L a few times and shifted the transfer case from high to low a few times. that or that process just takes the time it need to fix itself. its usually fine if i start it up and go immediately or if i wait a minute or two, but i think these two times i tried to go after less then 10 seconds, but the first one i drove a block (that start was fine), shut it down, met with my friends, figured out where we were going, started it again, and it did the gear thing
From what you're describing, I don't think the transfer case has anything to do with this issue, as it is directly gear-driven (aside from the VC, but you said it drives all four wheels anyway).
Sounds to me like one of the first gear clutch packs is slipping a bit... When (or if) it happens again, place the tranny in Manual-first ('L' on the selector) and see if there's a difference. Manual-first engages different clutch packs than when in Drive-first.
If it acts the same, then the Forward clutch pack (engaged through all forward gears) would be a possible culprit. OR, the kickdown cable (runs from throttle body to tranny) is out of adjustment.
Question: Does any slippage occur while cruising, downshifting, accelerating (aside from the main issue)?
It could be starting out in 2nd gear... Tell me, is there a "2nd Start" button on the dash or console?
assuming slippage would make a noise, or make some physical thing very different, i dont believe it does
Slippage typically doesn't make any kind of noise. It occurs when one or more clutches inside the transmission aren't engaging properly and are slipping across each others faces, much like the clutch in a manual transmission.
However, unlike a manual's clutch, you wouldn't be able to feel the clutch(s) actually slipping because the shock is absorbed by the fluid in the torque converter. The only way to tell if the clutches are actually slipping is when the engine revs higher, not matching speed or acceleration (just like what you've described).
no. didnt know there was such a thing.
Ok, that probably came on the later 95-97's. No matter.
Do a test for me... Start the vehicle and put it in 'D'. While holding the brake, push the throttle to the floor and note the RPM the engine maxes at. Should not be more than 2000 RPM. Do the same in '2' and 'L'.
Note- Do not "powerbrake" for more than 5 seconds at a time. Prolonged powerbraking will result in burning the tranny fluid. :steer:
