80 front third question.
Salt Lake City, UT
I am wondering if someone could point me to a thread that would tell me if there are any similarities between the 80 front axle 3rd member and a Tacoma/Mini truck 3rd member. Bolt pattern, r&p, etc. etc. I have used the search tool with no luck. However I have been limited on time. Any help or direction to previously posted info would be great. :cheers:
They are only similar because they are both drop out third members, other than that, completely diffrent. 80 series front ring and pinion are reverse cut gears(high pinion front end).
Hope this sheds some light for you.
The carriers are identical, actually. Same parts. The non-elocker diffs have 2-pinion carriers just like the 4 cyl mini-truck diffs. The e-locker diff has the same 4-pinion carrier as the V6 diff, and the pinion bearings are the same too. But the gears are totally different, because the 80-series diff has to be reverse-cut.
That's the info that I am looking for. Thanks! I do understand the reverse cut gears difference. To be more specific I am wondering if the 3rd cases are the same 80 e-locker vs V6 diff and non-locker vs 4-cyl mini truck diff. Same oiling passages, bolt mounting pattern and any other similarities? I am just trying to gather some cross reference data. Thanks again KLF! Forgive the redundancy of the question. I am just making sure that I understand correctly.
No they are not the same.
The e-locker has two different sized carrier bearings to allow the locking collar to pass through; the housing is completely different compared to the V6/4cyl, and is also not the same as a non-e-locker high-pinion housing.
The V6 housings have significantly more web reinforcements in the castings compared to the 4cyl.
Does any one have pics of the Taco and Mini stuff. I trust what Poser is saying. How about the V6 e-locker rear vs the 80 e- locker front? With the exception added webbing on the case.
Go here:
Erik's Toyota Differential info
Pictures posted below show a 4cyl third with a cut out factory E-Locker flange bolted on:
