80 fan switch
Plano texas
All right I know it must be easy to replace the fan switch in my 80. However after removing the cluster,and front trim pieces I still can not get the swich out .Any ideas? Then I thought I would replace the drive light :I figure it must pop out thrugh the back of the cluster...? Mike
:confused:
got pics of what you're trying to remove?
Seems like you're stuck in the same situation as me. My Med/Hi (#3 position) doesn't work.
What is the "front fan switch?" Do you mean the switch that controls the rear heater? It should just pop out after you take the trim piece off and you can reach it. It has tabs on both sides that you compress to pull the switch out.
I'm going to give you the same advice I give everyone before screwing around with the trim in these trucks: turn the heat up and let the plastic get warm for a while. If the plastic is cold, it tends to get brittle.
Ahem...
I think he means the HVAC controls.
Yes, the front fan switch . I called the dealer ,they did not know either,big suprise! Mike
:confused:
does the FJ80 have different switches than the FZJ80?
I know not of this fan switch, nor can I form an image of one in my mind.
I must humbly admit that I require assistance in the form of an image, posted henceforth, in order to provide further assistance.
I think he is talking about the switch which you turn ON/OFF the AC/Front heater. It has a few buttons for fan speed, and a slider for temperature control.
You mean the climate control system? Maybe he is, but that doesn't sound to me like what he is describing. There would be no reason to take off the trim pieces if that were the case, as those buttons are clearly attached to the climate control system unit. I think that he is describing the rear heater rocker switch, because one or more of the bulbs is burned out and he wants to replace it/them.
:confused:
I remember seeing FJ80 with "analog" panel, while the FZJ80 has the "digital" panel.
Edit: 1992 FJ80 pic.
