80 axle splines
Melbourne, Australia
Hey Guys.
Thought this would be the best place to post this
looking for the best option to coil spring my '40 atm and may have come up with a reasonable solution.
I originally wanted to run 80 axles and frame with the 40 body as many other have done, but don't like th massive fenders required to run such a wide axle
I noticed the rear axle shafts are 36.375" & 29" and the fronts are 17.75" & 34"
by comparison the 40's are 35.875" & 24.125" in the front and 17.25" & 29" in the rear
IF (where i need your help) the rear 29" axle shaft will work in the front (same spines as the birf/diff) or can be easily made to work I'll only have to get a second 29" axle shortened to 23.85" for everything to line up perfectly. This would make finding spares (if i ever need them) easy, and i'll just have to carry 1x shortened axle on the off chance it fails.
any advise or other recommendations would be great, another option at this stage would be gu/gq patrol axles, but struggling to find axle length info. I know front/rear axle shafts are not interchangable (custom shafts required though)
Cheers,
Luke
mkst likely you will have to just have custom inner axles made for the front, don't think you will be able to cut the rear 29" down and have it re-splined due to the lack of girth at the cut down end.
Yeah thought that may have been the case for the rear
if anyone can confirm that the spline on the axle shaft that mates with the birf is the same as the rear i'll go with 80 series chassis/running gear as it'll only need 1 custom shaft (easier for spares), otherwise i'll likely go with gu patrol axles/frame for the larger 10.5" diffs all round with custom axle shafts and it will also allow me to legally run a transfer case handbrake.
Could you just run 255/85 tires and use backspaced rims (basically any other Toyota rim besides the 80 rim)?
Want to run standard 16" toyota splits, so can only increase the width of the axle by about 1-2" max
'69-'97 30 spline at the diff and 27 at the birf.
Why not use 7X axles if you're wanting 40 width?
Want to run coils all round, only 7X series that has coils all round are the bundera's in Aus and they can only tow 1500kg, so not enough to tow my track car if I have to borrow a heavy trailer or if i load it up with tools, spares, fuel, wheels, etc
