79 FJ40 Ignition Igniter System Question
On my 79 FJ40, Im dealing with a no spark situation, and have replaced the cap, rotor, plugs, wires and coil. Still have no spark. I have bypassed the igniter box, as instructed in the service manual, and still havent had any luck. The manual says to install a .22 uF capacitor, with one side of it installed on the (-) side of the coil, and other other side grounded to the battery. According to the manual, this should work and make it spark, but it doesnt. Any ideas? Is there a Pertronix kit available to bypass all of this? Thanks for any help.
If the ignition system is fully electronic, do you have to run the ignitor or can you do the bypass with the capacitor that the haynes manual shows? Also does Pertronix make a kit that simplifys this ignition system up or is that deal only used to get rid of points? And people are talking about DUI distributors for these motors. Would one of these work for me and is it just a simple hook up? How much do they run and where can you get them? Thanks.
You need to run the ignitor with the Toyota electronic set up, which according to many is better than a DUI.
This is where I have purchased the DUI's that I have installed...
Yes they are simple, but from what I have read, installing the Toyota electronic is just as easy....
Are you sure that you have power going to the ignitor and positive side of the coil when the key is in the on position?
I would spend the 50.00us or whatever for an ignitor from a yard and try and get your Toyota unit working, before dropping the money for a DUI...but that is just me.
Good luck!
-Steve
Yes. I would like to keep it, basically because I am trying not to spend a lot of money. The PO had it cut out of the vehicle though. I am trying to see how it is wired. I don't know what wire coming out of the ignitor goes to where. Anybody know the wiring on them? Thanks.
scaned 79 elec diagram
I've been trying to scan this thing and change it so I could post it here.
I hope you can read it and it helps.
rompinredneck said:
It is fully electronic.
The bypass technique w/ a condensor (capacitor) only applies to the points ignitions used on 75-77 USA trucks.
It can't work on the 78-newer electronic ignitions. Be careful that not to burn up the pickup coil in the distributor by applying 12V to it.
Is there a way to test the ignitor assembly? Also can you do a test on the pickup in the distributor? I did a couple voltage checks and when I swtich 12 volts to the positive side of the coil and have the tan lead from the box hooked to the positive side, I only get 2 volts. That doesn't seem right. So I took both terminals off and then when I checked it, I got 12 volts coming from my source. Is this right? Does the ignitor take the voltage way down? Also, I had no voltage in either wire going to my distributor with the ignition switch on. Should I have voltage when applying power to the coil/ignitor? Any help or suggestions would be great. Thanks.
The wires from the distributor are a signal genrator. They do not get voltage. They produce a small (millivolts) signal when the distributor is spinning. There is a continuity test for the sig generator. don't remember the number, it's in the FSM somewhere. Something like 200-300ohms?
I test ignitors by applying 12V+ & 12V-, and connecting to a known good dissy. Spin dissy and coil should spark.
There is a test that will allow you to test the ignitor using a 12v bulb for very short periods if I remember correctly, it should be in toyota service manual.
You can replace the ignitor with a MSD unit..
$100 and you are off..
Do the pickups in the distributor usually go bad? The ignition will work fine with the MSD unit? Where can you buy the correct MSD box? Are the hook ups the same with the MSD unit? Thanks.
Also does anyone know the number of ohms the pickup on the distributor should test out at? How do you do this test? Thanks.
Yes they will work with a MSD, you cvan buy them almost anywhere. Try Jegs or summit.
Hookups are simple. You use the stock mag pickup to tell the computer when to fire.
Look up a 6A or a 6AL
I had one in my fj60 go bad. It was intermittent at first which drove me freakin' nuts;) I ran the fsm ignitor tests, which proved it good, and pretty much narrowed it to the signal generator. They're $275 at the dealer:( It was cheaper and easier to find a used dizzy.
