all. I am pulling apart my transfer case and am stuck in a few places.
1. How do you remove the main shaft that hold the two gears in he center if the case? I pulled the retaining piece
and used an aluminum rod and brass hammer to try to drive it out from front to back.
It does not seem to be budging. Just hit it harder? Arbor press? Drive from other side?
2. Having trouble getting ring the output shaft and gears out. Seems like he bearing is pressed onto the shaft. I’m assuming that it is drawn on when the nuts on the end of the shaft are torqued?
Do I just drive the shaft through with a brass hammer?
Thx for the help guys.
